Results 1 to 18 of 18
Thread: Best structural .035 or .045 flux core wire.
    MA
    Im looking to run a more structural wire in my miller 211 for a repair on a tractor loader arm. As I understand innershield 211 is not the best wire for this type of repair. The thickest metal in this repair is 3/8 but the arm itself is 3/16.
    The issue that I am running into is that it looks like many of the more structural flux core wires are larger diameter than .045.
    I may just sell the machine and buy an xmt 304 to run with my ln25 but i really like having the 211 as a backup machine, I bought it new.
    If there is a .035 wire that would be ideal because as it stands i would have to buy rollers, liner, and tips to run .045 in this machine anyway.
    Re: Best structural .035 or .045 flux core wire.
    I don't believe there is, especially in a self shielded flux-core. If you have a cylinder and flowmeter, you could use .035 solid MIG wire.
    MA
    Well at the moment I am working outside so flux core really makes my life easier. I dont have the volts to run dual shield with this machine or else thats what i would do and set up some barriers. I was under the impression that flux core is not really a downgrade from mig welding with solid wire if you disregard the visual differences.
    NR211 is a general purpose wire and doesn't require any impact test requirements and isn't for dynamic loads. Solid Wire is essentially a low hydrogen process and does meet impact requirements and is for dynamic loads. Technically for structural short circuiting circuit isn't allowed but for a loader frame it would be fine if you ran it hot enough and got good fusion. Being outside is a problem though unless you can put something up to block any wind.
    Mar 2012
    Australia
    Are large diameter 7018's an option, a 200 amp cc mathine will run a 5/16 rod, and wont loose out much in the depisition rate to a 211 Mig
    5/16" I think you'd need over 400 amps if you could even find a 5/16" rod. 3/32" 7018 would work fine for a 3/16" loader arm.
    Visalia, CA
    nr-232 or 233 are both lincoln structural flux cored wires. i wanna say you could get them in .045
    211 isn't terrible. its not recognized i guess, but.
    how much equipment is held together with 6011? thats what i compare 211 to. take it or leave it, will likely hold, just with a little bit of bashing from anybody who has had to work to "code"
    bosses stuff:
    trailblazer 325
    maxstar 200
    my stuff:
    sa 200
    fronius transpocket 180
    100 amp Lincoln w/f
    97 f350 DIT
    Kevin
    May 2007
    given what you mentioned you got to work w/, i'd go w/ nr211, and preheat, multi pass if needed. .you might be surprised how far you can crank the heat and feed up on .035 if you look at a chart. nr211 was used for structural probabaly more than you think 20+ years ago, so i wouldn't exactly feel guilty using it. ideally i'd favor 7018 over any wire for tractor arms. the smallest structural t-8 innershield wire i've been able to find is 1/16 dia., which might be a lil on the heavy side for 3/16 loader arm repair
    Mar 2012
    Australia
    Sorry! 5/32!! I work in the metric system, so trying to convert to inch fractions sometimes fizzles my brain, im talking 4mm rods
    May 2010
    Port Orchard, WA.
    Before the Northridge earthquake in California, and all the wire manufactures put thickness limits on their wire. I have no idea how many 1-inch side bend tests I passed with Hobartís 21-B.
    I think it was last summer I found a roll of .068ď NR-211 in the top of my Dadís barn. I took this wire off a job in the early 1980s. I ran a V-butt test with it. Reason I did this, over the years several welding inspectors told me they never seen any body pass a bend test with NR-211. Mine passed.
    I did some fillet weld break tests. Lincolnís Mig wire L-56 took 29-blows from a 4-pound hammer. I beat the top plate down on top of the bottom plate, then had to beat it back the other direction to break it off.
    Far as T-8 wires go, Iíd say Lincolnís NR-233, and ESABs Coreshield 8 are the most user friendly.
    Donít pay any attention to me
    Iím just a hobbyist!
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    Aug 2011
    Cape Cod, MA
    For your welder, I think that Hobart Fabshield 21B or Lincoln NR-212 are about the best wires out there. They are not "code" wires but are better than NR-211, which is limited to 5/16" maximum thickness. I have never seen T-8 wires smaller than .062" so I don't think they are an option for your machine.
    If you see yourself doing more jobs like this in the future, the XMT304 sounds like a very good choice. You will have the ability to run larger Innershield and dual-shield wires as well as stick. You will need an Innershield gun for the larger Innershield wires, however.
    John
    A few welders
    A lot of hammers
    A whole lot of C-clamps
    MA
    Quote Originally Posted by Silicon-based View Post
    John
    Yeah the icing on the cake is that I have been collecting what i need for a more powerful inverter setup, just havent finished the hunt for a xmt yet. I have an ln25 with the k126 flux core gun .063 drive knurled drive roller, and about 300 feet of 02 welding lead i bought at auction for cheap.
    To be honest considering the amount of time its going to take me to do this project i will probably find one before i finish the fabrication. I have to split the tractor in half inorder to plate the arm correctly so its going to take a while.
    I was going to ask about the 212, it is rated up to 3/4 it says.
    Feb 2015
    Atlanta-ish
    Quote Originally Posted by sparky24 View Post
    This XMT has been on the market for a while now (the ad has been published several times, with the price dropping each time): http://atlanta.craigslist.org/atl/tls/5169363325.html
    I'd wager he'll take a fair amount less for it, and it's been for sale so long, he'll probably ship it.
    -Chris
    May 2010
    Port Orchard, WA.
    Iíll take NR-212 over NR-211 any day of the week.
    I ran this NR-212 weld on a CC only engine drive.
    The NR-211 was ran with my V350-Pro on CV.
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    Northern Cal., Shasta County
    I'd guess that as long as you stick with the T-11 wires that's as close as you're gonna get to a small dia, flux cored, self shielded, structural wire . From time to time some of the T-G and even T-GS wires from manufacturers claim to be the same as such n such, but, the thing is they aren't required to be so there fore can't necessarily be relied on from one time to the next. That's the this is "chocolate , this "tastes" like chocolate thing marketing comes up with.
    I run a bit of and prefer the Hobart .045 T-11.
    http://www.esabna.com/euweb/awtc/lesson7_29.htm
    Nov 2012
    new york city
    i agree with wdave but don't recall having cracking problems with the 211 ever. even 1/8" 7018 would do nicely.
    i.u.o.e. # 15
    queens, ny and sunny fla
    NR211 is really designed for dynamic loading. 6010/6011 are. There's thousands of miles of pipelines welded with 6010, NR211 not so much. LoL The fact the original loader arm cracked tells me you want to do a good repair so it doesn't crack again. I'd do it with stick if it was mine. Probably a 6010 for full pen followed by 7018 cap.
    Sep 2008
    SF bay area, CA
    I have a couple of welders certs that date back to the mid 80s that are D1.1 3G unlimited certs that were run with NR-211 on CV machines back in the day. that And NS-3M. theres alot of structural steel out there welded with NS-3M thats no longer Seismic but still holding just fine
Page generated in 1,627,733,556.44296 seconds with 12 queries
