Results 1 to 8 of 8
Thread: Need Help Deciphering Welding Instructions
    Aug 2015
    Sarawak, Malaysia
    Hi guys.
    I'm a newly appointed Welding Engineer in a small company and I am the only engineer currently so I need you guys' help. In a drawing from our most recent project, the connection instructions include, and I quote directly, "Weld =8 FW/440". I was working at an inspection company before so I don't really understand what it means. Any help will be much appreciated.
    Nov 2012
    Re: Need Help Deciphering Welding Instructions
    8 mm Fillet Weld ?
    No clue on the /440 to beam
    terrible drawing
    call the drafter
    Aug 2015
    Sarawak, Malaysia
    Thanks for the response Timmy. Ye I figured it was 8mm Fillet Weld. But the /440 I have no idea what that means. Here's other parts that also says the same thing.
Size:  35.3 KB Name:  weldingforum3.jpg
    Sep 2012
    Wheatland, Wyoming
    I've worked with welding symbols at many jobs and never saw anything like that before. All I can think of is ask for their welding spec as it may help you decipher it.
    Chris
    Auction Addict
    Jun 2008
    8mm weld as TT said, it looks as if the 440 and 100 have to do with the length of the weld....somewhere....Mike
    Apr 2004
    British Columbia
    Weld =8 FW/440........would think that the 440 part is short for 440n/mm2 and refers to yield strength and rod selection. This Lincoln page for 6010 shows the 440n/mm2 notation near the bottom.
    Jan 2013
    ...Shoulder of Orion...
    @ OldSparks - concur. Seen similar notation in DNV classification for welding offshore structures.
    Aug 2015
    Sarawak, Malaysia
    Thanks so much for the replies @milo, mike and oldspark. I will call them and see if I can figure this thing out. Cheers guys!
Page generated in 1,652,811,864.01262 seconds with 12 queries
