Results 1 to 10 of 10
Thread: Hobart Champion 16 no weld, but has power at outlets
    Jul 2012
    Quit welding but has power at outlets(125 v) blows F-2 fuse. After some trouble shooting/tested bridge rectifier and its bad, replaced it and still blows fuse. After more reading tested capacitor and its bad and have one on order. What else should I check, this the model that is CV capable.
    May 2008
    Orange, TX
    Re: Hobart Champion 16 no weld, but has power at outlets
    You still have auxiliary power with fuse F2 blown? F2 is in the initial field flashing circuit and if blown you shouldn't have weld or auxiliary power output.
    However, to answer your question, if flashing diode D1 is failed shorted (closed) this will cause F2 to blow once the generator started to produce exciter AC voltage output on leads #28 (#5 after fuse F1) and #29).
    Do you have AC weld output only or DC too? If AC only then you have a bad connection or failed open diodes in the weld output rectifier CR2 or bad connection at the range selector switch.
    If neither AC or DC weld output then you need to check for an open in weld output lead #70 from the main generator.
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Jul 2012
    Thank you for advice/tips , will check it out and will also need ton find a schematic.
    May 2008
    Orange, TX
    You can download the Owner's Manual here:
    http://www.hobartwelders.com/service/owners-manuals/
    There should also be a schematic attached to the inside of the machine wrapper.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Jul 2012
    Tried to put serial # at Hobart website does not work # 197WR01943. Printed a schematic without serial # and the fuse blown is F-1.
    May 2008
    Orange, TX
    SN should be two letters followed by six numbers.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    May 2008
    Orange, TX
    If the bridge rectifier was bad that would explain a blown fuse F1.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Jul 2012
    Not enough hours in a day to mess with welder, this one is from my regular work. This machine is early 90's gray in color with CV. Will post update as time allows.
    Jul 2012
    Installed new bridge rectifier, capacitor and new fuse today and she welds. Thank you advise and help.
    May 2008
    Orange, TX
    Glad to hear it's up and welding.
    Thanks for the update.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
Page generated in 1,713,289,887.42712 seconds with 18 queries
