Results 1 to 10 of 10
Thread: Question of the week.
    Ceres, California
    This picture is of two pieces of metal welded together.
    Now for fun lets guess what both plates are and what process was used.
    alloy not important. If you know wait a few days before posting.
    Let everybody else have a chance to guess first.
    Re: Question of the week.
    Al to galvanized CS, Fronuis CMT
    Experience is something you get right after you need it
    May 2008
    Orange, TX
    Unobtainium to Expensium via explosion welding.
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Ceres, California
    Fred is right. Just got back from a training class at Fronius. They are quite proud our their CMT process. In the above picture the top aluminum plate is welded to the galvanized coating on the lower steel plate. With out damaging the coating. At some point you may see this in cars. Galvanized steel frame and aluminum body panels.
    This welding system not only uses advanced welding wave forms, but they move the wire up and down at the same time. Wave form and wire are synchronized.
    Jan 2013
    ...Shoulder of Orion...
    The CMT Puls wire printing (cylindrical pin, pike pin, print pin, etc) is cool. Wil have to explore the publised polarity/waveform outputs. Familiar with Lincoln's synergistic pulse and pulse on pulse.
    Fronius appears to have Gandalf the White at the helm.
    DARN, that sure looks like the new improved JB WELD .
    Jan 2008
    Richmond, Virginia
    Al to galvanized... didn't I see that at a county fair with some of the zinc/aluminum brazing rods?
    Syncrowave 250 w/ Coolmate 3
    Dialarc 250, Idealarc 250
    SP-175 +
    Lincwelder AC180C (1952)
    Victor & Smith O/A torches
    Miller spot welder
    Jul 2009
    SW Washington State
    Hello ccawgc, I was first exposed to this at a welding instructor's conference in Washington state up in the Seattle/Tacoma area, even got to play with running it. I believe that was around 8 to 10 years ago. It is quite impressive and "only" Fronius could come up with it. I believe that a number of high end automakers specifically call out Fronius equipment for repairs to their cars, can't remember which ones however. Fun and informational question. Best regards, Allan
    aevald
    Ceres, California
    While at their school they showed us a sample of some of the things their machines can do. They can control the arc so tight, they can weld the end of the wire to the plate
    then burn the wire in two at a predetermined length leaving a pin sticking up from the metal ( post 5 talked about this ). Connected to a robot this machines can do some amazing
    things. One of my customers builds light rail train cars and is switching from Lincoln to Fronius.
    Their High end welders are 3 phase only.
    That Al to Galv CS works pretty good, but it isn't magic, I snatched some up at the last AWS Show and pulled em apart, The galv pulls off the CS base metal medium easy
Page generated in 1,635,011,398.44066 seconds with 12 queries
