Page 4 of 4 FirstFirst ... 234
Results 76 to 94 of 94
Thread: Buying a Miller 211. What else to get?
  1. #76
    Sep 2015
    San Jose, CA
    I was using C25 at 20 CFH And I was pushing
  2. #77
    Feb 2015
    Austin, TX (now) -- Boston, MA (then)
    Re: Buying a Miller 211. What else to get?
    Try slowing down. Just watch the puddle wet in to both pieces of metal and keep moving - at a pace when it's always doing that. The arc is a little stiff.
    Millermatic 211 w/Spoolmate 150
    Hypertherm PMX45XP
    Wishlist:
    HTP Invertig 221
  3. #78
    Laredo, Tx
    Quote Originally Posted by DerekV View Post
    So I've been wanting to do this for awhile and I managed to find some time the other day. I wanted to get a good idea of what I can do with this machine with my current equipment and 0.030 wire. To be honest, I surprised myself.
    Room temperature (no preheat whatsoever) 3/8" mild steel lap joint, mill scale flap disk'd off, and clamped to a random 5"x5"x9" aluminum block I have (to prevent warping and to suck out as much hear as possible in order to showcase this 211's power). Single pass, 0.030 L56, voltage maxed, WFS="85", straight argon tank @ 15 CFH, C25 tank @ 13 CFH (combined ~92/8 ArCO2 mix @ 28 CFH). No spatter, no weave, straight push right to left.
    Attachment 1254171
    Attachment 1254201
    Attachment 1254211
    Attachment 1254221
    Attachment 1254231
    Spray transfer
    Hmm... Interesting. I haven't bothered to learn more about MIG other than typical short-circuit with C25, but you have my attention now. So is spray-transfer simply the use of an argon-rich mixture, with the lesser gas component being O2 or CO2, along with altered voltage/current parameters on the machine, correct?
    HTP Invertig 400
    HTP Invertig 221
    HTP ProPulse 300
    HTP ProPulse 200 x2
    HTP ProPulse 220MTS
    HTP Inverarc 200TLP
    HTP Microcut 875SC
  4. #79
    Feb 2015
    Yes, pretty much. With CO2, the % needs to be less than 20%. I can't remember the O2 % window off the top of my head. Both mixes are primarily argon. I'm using CO2 because that's what's already mixed in my C25 tank, how convenient!
    Lincoln has a GMAW PDF on their site that explains spray in more complete detail, I highly recommend checking it out. To put it very simply and quickly, with spray, the wire melts before touching the workpiece, and the droplets are smaller than the diameter of the wire being used. It is spatter-free, is very efficient, has high deposition rates, and provides a deep "finger-like" penetration profile. It can also permit faster travel speeds. Additionally, smaller wires get into spray with less volts/amps than larger wire.
    Spray is made possible with high voltage, high amps (again, wire size dependent) and an argon-rich shielding gas. The gas works to provide an easy path for the current to flow through. The more argon, the "easier" (aka less required voltage) it is for the machine to get into spray. Too much argon and you don't get good wet out or tie in --- too little and you can get some serious spatter (globular transfer). CO2 requires more voltage for the arc to establish, period (for short circuit, too). Larger machines have the cajones to run proper spray mixtures (85-95% argon + 5-15% CO2) with big wire at high amperage because they have the voltage to back that up. Voltage that exceeds regular short circuit parameters.
    Max available voltage almost always drops as the current increases, and this is important. Not all 200 amp class MIGs are the same! Look at the available volts at max amperage and you'll see what I mean. I am by no means an expert, but from what I've gathered, 180-220 amp (mild steel) spray on a 90/10 ArCO2 mix wants 25-26 volts. The new Millermatic 211 has that. My testing confirms that it can in fact do it AND do it well
    And yep, still 38 lbs dry
    Hypertherm PMX45XP
    Wishlist:
    HTP Invertig 221
  5. #80
    MA
    Well if you ever decide to sell the miller has great resale value, i paid 1100+tax for mine in 2013 and sold it last weekend for 1000. Not saying you will want to sell though .
  6. #81
    Feb 2015
    Quote Originally Posted by sparky24 View Post
    They sure do. I got almost all my money back for my Hobart too.
    The new 211 seems to be "a lot more welder for the money" compared to the older unit. I'll probably have this one around for awhile. A lot of power and "nice" features in a simple, lightweight unit
    Hypertherm PMX45XP
    Wishlist:
    HTP Invertig 221
  7. #82
    MA
    The first machine i bought was a hobart 140! i bought it at tractorsupply on sale for 359 or something like that!! i sold it for about 40 bucks more than i paid!!! B
    ecause the price bad shot up on them for some reason! lol. I thought it was funny, then i rolled that money into my 211.
  8. #83
    Laredo, Tx
    Thanks, I think I'll be trying that, since I too have an argon tank, and one C25 tank as well. Cool stuff.
    HTP Invertig 400
    HTP Invertig 221
    HTP ProPulse 300
    HTP ProPulse 200 x2
    HTP ProPulse 220MTS
    HTP Inverarc 200TLP
    HTP Microcut 875SC
  9. #84
    Feb 2015
    Don't you love when that happens??
    Hypertherm PMX45XP
    Wishlist:
    HTP Invertig 221
  10. #85
    Feb 2015
    No problem! I have check valves for each flowmeter at the T. They might not be totally necessary but they certainly provide piece of mind. A good starting point is going 50/50 with the gases (i.e. 12 CFH + 12 CFH). That'll give you an 87.5/12.5 ArCO2 mix. I've found that it's best (for the MM211 at least) to get in the total 24-30 CFH range. If you want to mess with the ratio, do it on the straight argon reg/flowmeter. Just be mindful that even little changes can be the difference from 80/20 to 92/8 ArCO2. I made a chart in Excel that has the gas outputs for individual tank flow changes...I can send it to you if you want.
    I still need to try this on 0.035.
    Hypertherm PMX45XP
    Wishlist:
    HTP Invertig 221
  11. #86
    Laredo, Tx
    No worries. I got about 8 classes of calculus under my belt. Ratios and percentages don't phase me.
    HTP Invertig 400
    HTP Invertig 221
    HTP ProPulse 300
    HTP ProPulse 200 x2
    HTP ProPulse 220MTS
    HTP Inverarc 200TLP
    HTP Microcut 875SC
  12. #87
    Feb 2005
    A little off topic but is anyone running Lincoln L56 .030 wire? What spool size of the L56 fits the 211?
    thanks
  13. #88
    Quote Originally Posted by Daskoff View Post
    thanks
    The old style 211 likes the L 56 .030 and takes the 12 pound spool. I bought some at ZORO at their 30% off one day sale. Hopefully they'll have another near black Friday OR the Monday following.
  14. #89
    Jun 2014
    Do the 10lb spools fit on these new 211's? I assume so but looks small. Ive got the old 211. Would love to compare them.
  15. #90
    Feb 2005
    I'm looking to buy the new 211 so I think it is much smaller...probably the 2 lbs would fit but I have not seen 4 lbs L56 wire or even 8lbs?.
  16. #91
    Laredo, Tx
    Quote Originally Posted by scramblerj View Post
    Yup it's tiny, just barely big enough to fit an 8" 10-12 lbs spool.
    HTP Invertig 400
    HTP Invertig 221
    HTP ProPulse 300
    HTP ProPulse 200 x2
    HTP ProPulse 220MTS
    HTP Inverarc 200TLP
    HTP Microcut 875SC
  17. #92
    MILLER STATES , '' Uses 4 inch or 8 inch (102 or 203 mm) spools . My current LINCOLN L56 .030 is 8'' diameter and 12.5 pounds.
    I bought a few at ZORO when they had 30% off. $43.93 /ea regular price so they were around $30.00 each
    http://www.zoro.com/lincoln-electric...Q&gclsrc=aw.ds
  18. #93
    Feb 2015
    thanks
    I take it neither of you read a single word in this thread...
    Hypertherm PMX45XP
    Wishlist:
    HTP Invertig 221
  19. #94
    Aug 2013
    Funny and true.
    The 8/3 cords mentioned earlier are great, I decided to buy 2 25' cords instead of the 50' one, cost me about $40 more but its worth that to me to not have to wrestle with the full length of the 8/3 if I don't need it on shorter runs.
    Brian
Page generated in 1,627,864,121.21486 seconds with 12 queries
