Anybody re-power a Lincoln Ranger 8? I know they came with either Honda GX620, KohlerCH20, or the Onan P216 which I have. Can anyone tell me what the crankshaft taper is?
Let's see if I can make a long story short...A while back I was welding with this machine and heard what sounded like ball bearings bouncing around in the crankcase, then the engine died. Got it running again and it's down on power, so I did a compression test. First cylinder 109 psi (sweet!), second cylinder 0 psi (Crap!). Next I do a leak down test on good cylinder and get 20%. I move to the questionable cylinder and guess what... I can't get the piston to TDC. In fact the piston does not move in the cylinder at all, so I am thinking I have a broken connecting rod. But the engine does run without making crazy noises.
Options: *rebuild the Onan which is a bit of a pain to get parts for and I am not a big fan of in the first place.
*find a used Onan with the right crankshaft
* re-power with a new or used Kohler or Honda
Anyone have some insight for me?
