Page 15 of 16 FirstFirst ... 513141516 LastLast
Results 351 to 375 of 396
Thread: The Official Craigslist Score Thread!
  1. #351
    Arizona
    Re: The Official Craigslist Score Thread!
    Yeah, I got BALLS!
    Copper is so good right now, it's worth it for the mine I go to to run all the ball mill waste through a screen plant to get the steel out of the ore, then reload the ore back into the process.
    There is literally a pit full of stray grinding balls now. The crew I help out said to take what I want, it's just going to get buried eventually anyways.
    A buddy mentioned making a grape bunch out of them. At approx. 8lbs/ea, that'd be one hell of a heavy bunch! I'm not sure they are even weldable...
    Yeswelder MIG-205DS
  2. Likes psacustomcreations, John Baptist liked this post
  3. #352
    This seems appropriate...
  4. Likes Shootr, RacerX liked this post
  5. #353
    Arizona
    It's on my play list already!!!
    Yeswelder MIG-205DS
  6. #354
    Oh, they're weldable.... even if only JBWeldable.
    What are the rod/spike things? Never seen anything like them before and already have visions of what I'd do with them running through my noggin. Are they mild steel? Cast?
  7. Likes Shootr liked this post
  8. #355
    Arizona
    Quote Originally Posted by VaughnT View Post
    Not sure what the spikes are. Since they seem to wear like the balls and come from the same area of the circuit, has to be something with the tertiary mills.
    Yeswelder MIG-205DS
  9. #356
    Looks like they'd make some great tooling for doing sheet metal work.... if they aren't brittle. See if you can heat one up and bend it 90º in the middle.
    Depending on the diameter's you could even use them as hammer blanks!
  10. Likes Shootr, Lis2323, John Baptist liked this post
  11. #357
    Picked up this 14" delta Rockwell 14" bandsaws with the low speed gearbox for metal cutting. Needs a new blade and the table insert. Pretty good shape overall. Found it on marketplace for $350.
  12. Likes N2 Welding, Lis2323 liked this post
  13. #358
  14. Likes Shootr, N2 Welding, John Baptist liked this post
  15. #359
    I got this lot from a retired silversmith a few years back. I got a real good deal so I will leave it at that....
  16. Likes VaughnT, 12V71, whtbaron liked this post
  17. #360
    New blade and switching around pulleys to get the 220 fpm really improved the cutting and greatly reduced vibration. Now to get various blades in different widths and tooth count to handle a variety of materials and for cutting curves.
  18. #361
    Also need to make up a mobile base to make moving it around easier.
  19. #362
    Original Rockwell, they made high end wood working tools. Nice score.
  20. #363
    I think it will work out good for my uses. Like every used machine tool I've ever bought it required it's share of adjustments and minor fixes to get it working decent.
  21. #364
    After lunch I went to look at this saw (block) anvil
    and ended up buying 2 x 40 feet of 2/0 welding cable with Tweco ends…
    this really clean Craftsman/Kennedy machinist tool box..
    and these three vintage dental cabinets..
  22. #365
    What kind of dentist uses Craftsman tools,welding cables and an anvil? New sideline coming?
    ---Meltedmetal
  23. Likes John Baptist liked this post
  24. #366
    I checked the backs of the drawers for "treasures" ( 14 carat gold fillings etc) but no joy
  25. Likes Meltedmetal, John Baptist liked this post
  26. #367
    My uncle was a dentist. First in the military, then he practiced in Bermuda until he retired. I got a smaller set of drawers from him but the only "treasure" in mine was some dental wax.
    ---Meltedmetal
  27. Likes Lis2323, John Baptist liked this post
  28. #368
    Jun 2021
    I have bought all my welders from craigslist...Well TONS of things from craigslist actually
    Airco Dipstick multi process 160 $150.00
    Lincoln squarewave 175 with torh, pedal and regulator $175.00
    Lincoln idealarc tig 250 $100.00
    Also a 110v mig welder I no longer have for $75.00
    Lincoln Idealarc Tig 250, Airco Dipstick 160, Lincoln Square wave Tig 175
  29. Likes John Baptist liked this post
  30. #369
    Arizona
    $20 for a brand new rolling, adjustable, steel stool.
    Yeswelder MIG-205DS
  31. #370
    Apr 2016
    CA
    SS A$$ pan not bad.
  32. #371
    Apr 2016
    CA
    Quote Originally Posted by A1cnc View Post
    Wow just wow!
  33. #372
    Apr 2020
    pekin, IL
    The best scores I've gotten from Craigslist has been my welding tanks. Picked up a T size and 2 - 42cf tanks that I swapped and eventually got upgraded at my lws to a T, a 125cf and an 80cf. Cost was pennies on the dollar compared to buying new...
  34. #373
    Apr 2016
    CA
    Todays find is a miller 330a/bp with a water cooled 20 torch, "no water cooler unfortunately" foot pedal, stick stinger and 200a tweco copper ground clamp all on a cart with big wheels. Super easy to move around. I'll need to swap out the torch or plumb in a garden hose to try this sucker out. I don't know the ins and outs of this thing just yet. Think I'll try to get the physical manual from miller before using it. It is suppose to be more extensive with usage etc. I'm stoked about getting it. Now to figure out a way to store it indoors so the weather don't beat it up. Its not brand new looking but it's not super ugly either. I can live with it.
Size:  71.0 KBName:  20210807_175357.jpg
Size:  117.7 KBName:  20210807_173321.jpg
Size:  88.5 KBName:  20210807_173306.jpg
  35. Likes whtbaron, Lis2323, John Baptist liked this post
  36. #374
    Apr 2016
    CA
    Oh yeah I forgot it came with the Harris flow meter as well.
  37. #375
    Please stop now
  38. Likes John Baptist liked this post
Page generated in 1,631,948,974.37964 seconds with 13 queries
