Page 30 of 30 FirstFirst ... 20282930
Results 726 to 746 of 746
Thread: The Official Craigslist Score Thread!
  1. #726
    Aug 2013
    Hudsons Hope BC
    Re: The Official Craigslist Score Thread!
    I was working in Ontario and saw a add for a drill press at home in bc for $60 in june. I called and talked to the seller when he said it was a big floor model I said I would take it. I sent him the money that day and told him I didn't know when I would be able to pick it up.
    Went and got it on Saturday I'm pretty pleased with my purchase. Name:  20220813_194158.jpg
    Lincoln 350mp
    miller regency
    miller syncro wave 300
  2. Likes whtbaron, LtBadd, Shootr, 12345678910, 455dan liked this post
  3. #727
    Arizona
    I've had my out for a piano for a while - I want the harp out of one for an art project. Last week, a mile from the house, someone put an upright out on the curb for bulk garbage pickup. A project to restore but they ran out of interest and decided to toss the whole thing - but listed it in case anyone wanted it.
    These suckers are HEAAAAVY. I brought my tools hoping I could pull just the harp out and leave the rest. I guess I should have looked up exactly how these are put together. I had every string cut, every bolt and screw out of it, but it wouldn't budge - like it was glued to the sound board or something. I ran out of daylight and time so had to leave most of it behind .
    I kept the top brace and the hammer assembly since they were loose already. Gotta be a use somewhere in them.
    Yeswelder MIG-205DS
  4. #728
    Isn't this the part where somebody pipes up and tells you that piano was worth $50k?
    Cut 50 Plasma
  5. Likes 52 Ford, Lis2323 liked this post
  6. #729
    I was out coyote hunting in the middle of nowhere once and found the remains of an upright piano that somebody had burned. It had a huge cast iron piece that the string were attached to.
  7. Likes 52 Ford, whtbaron liked this post
  8. #730
    Arizona
    Yeah, that's the harp - has to be stout to hold all the string tension.
    Yeswelder MIG-205DS
  9. Likes 52 Ford, 12V71, whtbaron liked this post
  10. #731
    Picked this up today, 9x,42 Bridgeport, step pulley. Has X power feed and a Trax DRO on it. Everything appears nice and tight.Name:  IMG_20220820_193324105.jpg
  11. Likes 12V71, Shootr, 455dan liked this post
  12. #732
Size:  199.1 KBName:  IMG_20220820_193302960.jpg
  13. Likes 12V71, Shootr, LtBadd, 455dan, whtbaron liked this post
  14. #733
Size:  112.8 KB. Should be a good machine for my used, it has a 4" and a 5" riser block stacked together on it now. I plan to keep the 4" block.
  15. #734
Size:  143.5 KB The dual hoist setup has proven to be invaluable once again. I could have adjusted the ram to center but the handle to drive the rack has a broken off bolt.
  16. #735
    Oct 2011
    Jacksonville Florida
    Picked up this compressor a few days ago for $150. It was only running while choked, cleaned carb, changed oil,
    replaced air filter and spark plug now it's running pretty good. Pumps up and drops to idle like it should. I think it was a good deal.
    Airco Ac/Dc 300 Heliwelder
    MillerMatic 200 (stolen)
    Miller Maxstar 150STL
    Miller AEAD200LE (welding and generating power)
    Hobart MIG
  17. #736
    Jan 2005
    Tried the Big 3 phase esab Transformer on the 460/3 of the Thermal.. Not enough juice to fire it off. It has to stay on my Rotary. Not all is lost, because my 3 phase 60i cutmaster, and Lorch Esab 220i is happy on the 460 power.. The Lorch will output 220 amps on 3 phase, and 200 on single phase power. It will used as needed.. Just gets it off the Rotary when I need a bit extra..
    Found another machine that will run on the Thermal's 460/ 3 phase. On Marketplace, and had to look past the dirt.. Turned out it was super low hours, and great shape overall Hard to find this much quality for so little money .It would sit on marketplace forever but not with me around..Perfect match in input/output power. Some people would not look past the dirt. Not me, because I could tell it was a good one under it all... $350.00
    https://www.facebook.com/marketplace...6141893514245/
    Esab/Lorch ET-220i
    Esab 160i caddy
    Esab CV353
    Thermal LM-200/ Lincoln feeders
    Thermal 60i- 3phase
    Pak 50
    Thermal 35C
    Thermal 15c
    INE 1500
    Klutch 220i
    Blue Demon/140 msi/90sti
  18. #737
    Oct 2016
    Needed a digger Craigslist worked out
    there are still some OK sellers on CL
    HTP Pro Pulse 220 MTS (Anniversary Edition)
    1962 Idealarc TIG 300 300
    1974 Idealarc TIG 300 300
    1988 HF Power MIG 150
    2015 Lotos Ltpdc2000d plasma/Stick/TIG
    Victor 100 torch, 200- 210 Oxy/Acet gauges
  19. Likes Brand X, N2 Welding, Lis2323, whtbaron liked this post
  20. #738
    Just bought this Tweco 600 amp C clamp style ground new in box.
    I paid $35 Cdn. (Approximately $25 usd )
  21. Likes Brand X, N2 Welding, 455dan liked this post
  22. #739
    I bought a vintage made in England Craftsman wood working vise ( needed a bit of cleanup) for $5
    sold it today for $45.
  23. #740
    Apr 2016
    CA
    Took a walk at the San Joaquin county fairgrounds fleemarket.
    Got 4 files for $6.00. & The old Sears grinding wheel dresser and big chisel both for $1.00
Size:  70.4 KBName:  20220914_115144.jpg
  24. Likes precivilization, 52 Ford, 455dan liked this post
  25. #741
    Dec 2020
    Virginia, USA
    Not that these tools really need it, but I've gotten into the habit of soaking old files in Evaporust. Might wanna get a gallon of it. I've been using the same tub of Evaporust for probably 3 years.
  26. Likes N2 Welding liked this post
  27. #742
    Apr 2016
    CA
    The big bastard file is right about perfect timing if and when I clean the cylinder decks. Square rat tail style file plus the regular rat tail and the other smaller bastard looking file are all American made files. Say made in USA on them and the teeth look good. I'll buy cheap files all day long.
    The guy that sold me the Sears grinder wheel dresser tool for a buck said go ahead and grab another. He must of liked our conversation. I went back to the car to see what change I had un the little cubby in the dash and came back with a buck. He was going to let me take what ever tools trusting that I'd come back and pay him. I told him no, because if I don't have the change in my car to cover it I don't want to walk all the way back here to give you the tool back. I think he appreciated that and the fact that I walked all the way back with a buck of change to get the sears grinding wheel dresser. He said go ahead grab any other tool. So I picked the big chisel. I'll have to look into that rusty stuff you mentioned.
    My eyes are soar atm. Did not sleep well last night and a friend of a neighbor was asking about my brothers cars. I shot the $hit with him for a moment then ran in the house fot the keys, started the 2005 camry, popped the hood and with it running then opened the trunck and saw the back seat/rack to his old Harley and lost it. Couldn't help but getting all choked up thinking about sending his stuff down the road. It's killing me but I need to make space for my stuff.
  28. Likes 52 Ford, whtbaron liked this post
  29. #743
    Dec 2020
    Virginia, USA
    My eyes are soar atm. Did not sleep well last night and a friend of a neighbor was asking about my brothers cars. I shot the $hit with him for a moment then ran in the house fot the keys, started the 2005 camry, popped the hood with it running then opened the trunck and saw the back seat/rack to his old Harley and lost it. Couldn't help but getting all choked up thinking about sending his stuff down the road.
    EvapoRust is honestly some great stuff.
    I take it you lost your brother? If that's the case, my condolences. Definitely can jarring when you get an unexpected reminder. I still have a bunch of my dad's stuff to go through...
  30. #744
    Even better than Craig's List, I found them for free! You just don't get natural patina like this over night...
    Cut 50 Plasma
  31. Likes SweetMK liked this post
  32. #745
    Dec 2020
    Virginia, USA
    EEEEVVVAAAPPPOOOORRRUUUSSSTTTTTT
  33. Likes SweetMK liked this post
  34. #746
    Dec 2020
    Virginia, USA
    Whtbaron! Buy a bottle of Evaporust. Take a before and after picture of those shears if you use it. Seriously!
  35. Likes whtbaron, 455dan liked this post
Page generated in 1,664,158,560.21895 seconds with 13 queries
