Results 1 to 14 of 14
Thread: Trailblazer 325 efi or carb?
    Sep 2014
    Greensburg Pa
    Hey guys and gals, finally saved up enough dough to buy myself a trailblazer 325. Plan to purchase it in the next week or two. Im still kinda undecided on going efi with the excel power or base model carburated. I really like the excel power option and i wish that they sold it with the option to go carb with excel power. Interesting how in another thread someone mentioned possibly making ur own excel power with a inverter hooked up to the battery within the trailblazer. Not sure if id want to mess with doing that and or if it would work well.
    The difference in the upgrade to efi and excel is around 700-800 dollars. I also am a little bit of a prepper and so the trailblazer would also serve a purpose of a backup generator for short term and possibly long term emergencies. Not trying to get off topic here, but the carb model originally was even more of a plus to me due to the fact that carbs are generally emp proof. I know there are all kinds of circuit boards in the welding side of the trailblazer but my figuring was that if a emp were to take out the welder electronics, i could possibly still get the gen set to produce power for me. - called miller and they said that even the carb model requires a circuit board in order to run. So seems that kinda is null on the emp issue.
    This things main purpose is to surve me in my welding business ive slowly been building over the last few months so if you guys have anything to say on the efi (with excel) vs carb id appreciate it very much!
    By the way, if i had the money it would be the pipe pro 350 as pipe welding could be in my future!
    Thanks a lot !!
    Dynasty 200DX (2014)
    Millermatic 211 (2015)
    Optrel 864 (2014)
    Smith Medium duty MBA 30510 (Xmas 2014)
    Tennsmith 16ga 4ft finger brake (2015)
    Trailblazer 325 EFI and excel
    Thermal dynamics Cutmaster 82
    Miller maxtron 450
    Sep 2014
    Greensburg Pa
    Re: Trailblazer 325 efi or carb?
    Oh and i know that a bobcat would be a fully emp proof machine, but not interested in one of those.
    Optrel 864 (2014)
    Miller maxtron 450
    Apr 2010
    Go with the EFI it will save you a lot on fuel costs
    What would SATAN do ??
    Miller Trailblazer 302 AirPak
    Miller Digital Elite
    Optrel Welding Hat
    Arcair K4000
    Suitcase 12RC / 12 VS
    Hypertherm PM-45
    Rage 3 saw
    Rusty old Truck
    May 2011
    Carb or EFI based upon EMP resistance? Either one still requires a working ignition system to operate. The coil (welding alternator, ignition coil, or starter) insulation was not likely designed to survive the large induced voltages from an EMP event without failure. Lets not talk about the EMP resistance of the alternator rectifiers in either version of the 325. You might be better off making your choice based upon real world functionality, serviceability, and cost than EMP. Consider an Oxy Fuel rig if post apocalyptic welding is your long term goal. Early VW Bugs and SA200s might survive, just ask Woody Allen (Sleeper 1973).
    Upstate NY
    Quote Originally Posted by AMillerUser View Post
    ...snip... Consider an Oxy Fuel rig if post apocalyptic welding is your long term goal. ...snip...
    X2!
    Until nuclear Armageddon, if you want an engine that will start every time, regardless of weather conditions, go with the EFI.
    Welders:
    2008 Lincoln 140 GMAW&FCAW
    2012 HF 165 'toy' GTAW&SMAW
    1970's Cobbled together O/A
    Sep 2014
    Greensburg Pa
    U bring up a couple valid points one of which i wasnt aware had sensitive electronics ( alternator).
    Well then. Aside from the emp thing and purely based on a functional and economic standpoint seems like the three of you above prefer the efi. Anyone else with input please post.
    Woodinville, WA
    Going to disregard the BS on EMPs since my job has had be deal with EMP analysis and basically, if you were near the epicenter of a nuclear based EMP, the engine in your generator wouldn't matter. From a standpoint of starting, fuel efficiency, and all temperature use, get the EFI.
    --Wintermute
    "No man's knowledge here can go beyond his experience." - John Locke
    www.improvised-engineering.com
    Manufacturer Agnostic:
    Blood----------Sweat---------Tears
    Lincoln Red, Miller Blue, Esab Yellow
    Sep 2014
    Greensburg Pa
    Quote Originally Posted by wintermute View Post
    --Wintermute
    Id appreciate it if elaborated on ur experience with emp. A nuke exploding high in the atmosphere wouldnt harm us with radiation, but would send out a emp across much of the nation (as far as i understand it). Not trying to get off topic too much here but whats ur experience with emp and elecronics? Thanks.
    Optrel 864 (2014)
    Miller maxtron 450
    Upstate NY
    Quote Originally Posted by outdoort View Post
    Thanks for getting me to read the Wikipedia entry on EMP.
    Yeah, really high-altitude nuclear detonations will cause a wide area EMP, but then there is little-to-no blast effect.
    Again, if you really need your welding rig to function after the nuclear holocaust, O/A is your only option.
    The EFI computer is only one of several critical pieces of electronics. The alternator, its regulator, the starter, the solenoid that engages the starter drive, ignition system. What about the controls for the welder? A 1940's or 1950's (early, simple, hand-cranked) engine drive might survive, but the exciter or magneto may not.
    (Rhetorically) How well prepped for this disaster are you?
    I grew up during the height of The Cold War. Most of my contemporaries were comfortable with "At the sound of the air raid sirens: Sit down. Place your head between your knees and kiss your azz goodbye."
    So, if I were in the position to buy a brand-new engine drive welder. I'd spend the extra on a Diesel. Only because Diesels hold up better than gas engines.
    My recommendation: Plan for the foreseeable future, not every possibility.
    Welders:
    Jul 2010
    Haslet Texas
    go with the efi....
    my TB325 with efi and excel can sit for months on end, and have no issues starting, no matter the weather
    it has 50 hours on it, I've only had to fill it up twice.. great fuel mileage
    excel power.. its nice running hand tools and charging batteries without it revving up
    Woodinville, WA
    Primary issue with nuclear EMP isn't the blast from the nuclear weapon. It's the EMP itself. My experience is in working with engineering on prototype weaponry development and the studies to protect those weapons against nuclear EMP. The primary issue for your generator (but more importantly for yourself, your house, etc...) is the 50,000v/m that comes with a nuclear EMP. Anything with a sufficiently long conductor attached to it basically gets cooked. For quite a few things, that sufficiently long conductor is the object itself (such as a ship, shipping container, wiring in a house, etc...). Your gen welder is no different, we found that dissimilar directly contacting metals would weld themselves together (think a piston, piston rings, and engine block). Additional affects of that kind of voltage transmission on the human body/nervous system were extreme...and disturbing (think being hit with a stun gun, but directly against your frontal lobe instead of on your skin). At the outer EMP edge of a low yield atmospheric nuclear detonation (like what was seen on Hawaii during Starfish) the v/m is substantially dissipated, however, no tests have been done with high yield nuclear detonations and the dissipation radius is purely speculative at this point. If you are within the core of the EMP (IOW, not far enough out to have substantial dissipation of the EMP), then you're not going to care that your gen welder doesn't work as you won't be around to care.
    --Wintermute
    Sep 2014
    Greensburg Pa
    --Wintermute
    Thanks for the additional details. Sounds like ur refering to a nuc blast on or near land mass. I agree with the fact in that instance emp wont mean jack because ul be dead. Im talking a high altitude nuc exlosion from a terrist. Supposedly the smaller nuclear bombs will give off even more of a emp blast when detonated in this fashion.
    Also lets not forget solar flares. They will give off emp just like what were talking about above, and i think i read somewhere that scientists say we are over do for a large one.
    Optrel 864 (2014)
    Miller maxtron 450
    Woodinville, WA
    No, I am not referring to a low altitude blast. I'm referring to a high altitude blast intended specifically to create a high grade EMP (which is really only a nation state item btw...I would highly doubt the possibility of a terrorist gaining access to a high altitude bomber or an ICBM).
    --Rama
    Sep 2014
    Greensburg Pa
    --Rama
    I agree, that its pretty unlikely something like this would happen, but a concern none the less. -especially with iran on its way to obtaining them. They are the worlds leading funder of terrism.
    Optrel 864 (2014)
    Miller maxtron 450
Page generated in 1,627,456,412.86667 seconds with 11 queries
