Results 1 to 7 of 7
Thread: 14 pin wiring
    Feb 2009
    Central Illinois
    14 pin wiring
    Are the 14 pin plugs on a Powcon and a Miller wired the same.
    Wanting to know if I can run my 30A spool gun on a 300SM
    Thanks Dan D.
    Manipulator Of Metal
    May 2008
    Orange, TX
    Re: 14 pin wiring
    The 30A has a 10-pin unless you're running it off a WC-24 which has the 14-pin but they are not the same from what I see.
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Feb 2009
    Central Illinois
    Re: 14 pin wiring
    Yes I am using a WC-24. I forgot to add that.
    Thank you Duane. You are always very helpful
    Dan D.
    Jan 2008
    Lansing, MI
    Re: 14 pin wiring
    Miller 14 pin is 20 shell size. Powcon stuff is 14 pin 17 shell size. The 17 shell is common on older Miller automated stuff and some digital readout wire feeder motor connections. If you need a connector, I have some.
    Dunno on the pin location, but I'm pretty sure it's compatible with Miller stuff, at least that's what Arcon told me.
    For Miller stuff pins A and B provide 24 VAC contact closure, pin G is circuit common. As long as the PowCon pins are in the same location, or you can make an adapter, I'm sure it'll work fine.
    Nov 2013
    Colorado
    Re: 14 pin wiring
    I have just done this it was a little tricky but can be done. http://weldingweb.com/vbb/showthread.php...remote-pinouts ,digikey has the plug and I have the part number for it at work. So by jumping 8 and 9 puts in in remote mode and jumping/closing 10 and 11 enables/turns welder on, I did this with the gun trigger. It has 16 volt out witch I would not recommend a 24 volt feeder you be better off using a 115v feeder. BTW the sm300 with out perform any welder in my shop burning 1/16 Metal-core and Ultra-core wire. The machine is a beast!
    Feb 2009
    Central Illinois
    Re: 14 pin wiring
    Quote Originally Posted by Sgnob View Post
    Thanks Sgnob. I will try probably give this a try.
    Dan D.
    Jan 2013
    Россия
    14 pin wiring
    I can get the range rover locally for 80 or the king cobra for 70. I would like to try a single pin, but not sure im ready to man up for an HHA. Which of those two is the better sight?
    без подписи
Page generated in 1,624,030,669.66555 seconds with 11 queries
