https://www.youtube.com/watch?v=aFLeBcaX5Pw
Are there any resistance spot welding machines that spot weld aluminum together well that are not propritary like GM's? cool tech that came out 3 years ago?
if not are there spot welders less than $2000 than can spot weld aluminum together? I read about the trick to use two pieces of steel to concentrate the heat.
IN my research I found a machine made by fronious that uses a sacrificail steel spool as well.
I was surprised to not find any dedicated aluminum spot welders, just work arounds.
