Results 1 to 12 of 12
Thread: Power tig dx vs dv
    Power tig dx vs dv
    Is there any difference in the 2? I read on one of the sticky post on her that the dx now comes in 110 or 240 but on the everlast site it says only the dv comes with dual voltage. I also have looked on Amazon and they have a 2015 dx with dual voltage for 1250 and a dx without it for 1350 on those 2 there is a diffrence in the machines front panel and one has a metal handle. I'm completely lost anybody know if there are 2 different dx machines and is there any diffrence in the dx and dv machine beside the dual voltage?
    Nov 2008
    Re: Power tig dx vs dv
    If it is advertised as a
    dx with dual voltage, it is a DV. Technically for now, all units are a 200DX-DV. The standard DX is only available in limited numbers and by the end of this year, with the 2016 models, all should be listed as DV, and will be dual voltage. All units have a metal handle in the last few years, probably using older/newer images as the outside is nearly identical. If it has an older face, it may be either old stock or someone selling used units.
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
    Smith Oxy Fuel setup
    Everlast PowerPlasma 80
    Everlast Power iMIG 160
    Everlast Power iMIG 205
    Everlast Power iMIG 140E
    Everlast PowerARC 300
    Everlast PowerARC 140ST
    Everlast PowerTIG 255EXT
    Is the 2016 model going to be different? With the new Lincoln coming out at around the same price and it almost being 2016 I might wait so I can compare the 2
    Nov 2008
    Compare apples to apples. That unit is closer to our 185 than our 200DX. It's somewhere between our 185 and Miller Diversions, except slightly higher amps. Almost no controls, low pulse capability with no adjustments other than Hz, limited cleaning adjustment, low duty cycle, not 2T4T controls and no adjustment of pre or post flow. Higher DC start at 10 amps versus our 200DX at 5. With our 185 having a greater range of control over AC frequency, it should have about as much capability when welding aluminum as well. Plus the lincoln is listing at 1399.00...higher for less. They are marketing it to a "dumbed down" crowd for sure. Our 2016 185DV will also feature a simple pulse setup as well...so it will again have more features as we've added 2T/4T functionality along with downslope to make the unit more flexible for people who go between the foot pedal and the torch switch.
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
    Any new features or updates to the 2016 model?
    Nov 2008
    Both 200DV and 185 DV will be digitally controlled.
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
    Feb 2009
    Chicago
    What about the 225LX? I have been wanting to try out the 200dx/dv or 225LX as my next unit
    Is it 5amp start on ac and dc?
    Hypertherm Powermax45
    Esab ET220i
    Razorweld 195 Mig
    Razorweld 200ac/dc Tig
    Tormach 770, Tormach xstech
    Razorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
    Nov 2008
    No, dc only.
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
    Feb 2009
    Chicago
    What about ac?
    Esab ET220i
    Razorweld 195 Mig
    Nov 2008
    Not sure if it will be 10 or 20 as the testing and fine tuning isn't done yet.
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
    Feb 2009
    Chicago
    Cool let me know. I'd like something that can do LOW on AC. 10 at the highest.
    So what is the lowest amperage on the current 200dx? And the 185dv? The AHP will taper down very very well.
    Esab ET220i
    Razorweld 195 Mig
    Nov 2008
    5 and 20, but I do know that with the foot pedal it can go down as low as 15 on AC before the arc breaks off, but the most stable level is 20 for AC.
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
Page generated in 1,635,341,908.56904 seconds with 11 queries
