Results 1 to 10 of 10
Thread: Lincoln or Miller
    Jan 2011
    St. Louis
    Lincoln or Miller
    I have the opportunity to purchase either a new Lincoln 225 welder/generator with the factory 3 year warranty or a used 2yr old Miller Trailblazer 302 LP rental unit from CeeKay welding with 603 hours and factory warranty until 2/12. I would like the experts input on which you would recommend. I mainly do ornamental work, but would like to be able to put a welder/generator on a trailer and do some mobile work. The price of both are within a few dollars of eachother. I have a shop to do the majority of my work, but would nice to be able to go mobile every now and then.
    May 2007
    Okanagan Valley.
    Re: Lincoln or Miller
    Given the choice between the two machines, If the price is right, you do a lot of field work and the machine has been properly maintained/LP is readily available, I would pick up the used miller. If you do a lot of ornamental work in the shop, you might almost consider a wire feeder as opposed to the 225.
    Aug 2009
    I loathe carbs, despise fecal modern so-called "gasoline", and second the LP choice.
    You could run the machine outside the shop and run a feeder inside the shop if you like. l leave my ESAB 450 inside my ISO container and use a voltage-sensing Hobart Hefty feeder in the small shop next to it.
    Hellinois
    Depends on the price difference. IF the Lincoln was THAT MUCH cheaper, then maybe. Otherwise, there is no comparing those two machines.
    "Stick-man"
    Jan 2011
    St. Louis
    I can get the used Trailblazer with the running gear for $200 less than the basic Lincoln 225.
    Sep 2009
    Pueblo, CO
    Trailblazer
    1981 Lincoln SA 200
    Miller Trailblazer 302g
    Miller 211 Mig Welder w/ Autoset
    I'm learning to stick metal together
    Jan 2011
    St. Louis
    jsm11. Looks like you're a little bias. Why do you like your TB?
    Hellinois
    I would go with the TB. Alot more power. More aux. power. Every one just raves about them.
    "Stick-man"
    Apr 2011
    Smiths Alabama
    trailblazer is the way to go
    the trailblazer 302 offers more process options than the lincoln, along with more generator power. it would be a no-brainer for me.
    I only drink when I'm by myself or with somebody
    miller deltaweld 452 w/s62 and xr-w
    miller trailblazer 302
    lincoln dc400 w/ln7
    eutectic tig rig
    hypertherm 900
    lincoln stt II w/ln742
Page generated in 1,634,863,883.15640 seconds with 11 queries
