I know I should probably "just go try it" but Im slightly paranoid about ruining my main welder. Also, the XMT cannot move, and is further from where I sit to weld than the pedal will reach. So I am trying to determine if its worth moving everything.
I have the xmt350 cc/cv, I added the gas solenoid to it as well.
I use it for almost all my welding (hence the paranoia), but right now I've using it for lift start tig.
I have a pedal for it thats still in the box, because I bought it thinking I could just plug it in and gain that nifty "push on the pedal to start the arc" ability. That and bring the arc down gracefully.
I've since realized I need a HF start unit, so I've kept doing lift tig. My question is this:
Assuming that my above statements are true, is there still any point to using the pedal if I have to start with a touch anyway?
