Electrode whip length
6.9K views 7 replies 8 participants last post by  Jase90
I have 100' stinger leads on both my shop and engine drive. Both are one continuous piece of 1/0. It works well. I just bought a LN-25 wire feeder and instead of making a long lead for it to run back to the machines I thought I would just put some twecos near the end of my stinger leads to connect it to.
I know a lot of guys have this set up for their stingers with a long heavy lead and then a short easier to handle whip. My question is how far back from the electrode holder should I make the cut? It seems I would not want it too close the the electrode holder as the couplings might get hung up on my work. What do people normally do 10-20'?
#3 ·
Depends on what your doing. If you are on ladders or on equipment a longer whip is good to have. I use 20' of #1 superflex for mine
#4 ·
I have 50' and 100' sections of lead. They have Tweco style connectors on both ends, male on the welder side and female on the other end. Kind of just like an extension cord. On my welders I have 1' whips with female Tweco's. On my suitcase wire feeders, I have a 1' whip with a male Tweco, to plug into the end of my lead. For my stingers I use a 10' to 15' whip of #2 or #1, and for my ground clamps I use a 1' to 2' whip of 1/0.
#6 ·
I use tweco quick connects and an 11' length of cable from the stinger to the first connection. The reason for the 11' is that I have been on jobs were the safety folks required you to have a minimum of 10' from stinger to the first connection for safety reasons. Needless to say we had to make some new whips one time and ever since I've made mine 11'. Also having them a little longer keeps the connection from getting caught all the time on what your working on.
#7 ·
Both of mine (I like different style stingers for different things) are 12.5' long because my LWS sells welding leads in 25' increments so I bought 25' and cut it in half. The Tweco connectors have never been in my way yet.
