Results 1 to 25 of 43
Thread: Tig root critique and advice.
    Dec 2015
    Hello I'm a 29 yr old in Jacksonville Florida looking to expand my knowledge and certifications I am currently 3g and 4g certified with aspirations to become certified in tig root and hot pass 7018 fill and cap and stainless tig in 6g. I"m looking to get out of the field im currently in to make a jump straight to welding pipe. I'm a material handler by trade doing just about anything inside a warehouse racks, conveyors, cranes, dock equipment etc. I have what I would consider a good job at 22/hour with truck and phone paid for as well as other small perks. But I want to jump into other things Im very mechanically inclined and a fast learner. I'm wanting to get into pipe welding/fab making the same if not more money I can mig tig stick aluminum stainless steel with quality outcomes I used to have a dynasty 200dx doing cast aluminum repairs and small stainless jobs even modifying aluminum boats so I'm no stranger to welding but at the same time I know pipe welding to the specs is a different story. So I started small I've got a cst 280 and some 3/8 plate beveled at 37 degrees that I'm starting out with since everything I will be doing will more than likely be scratch start tig. I"m just looking for some pointers and what to expect. Also what type of certs will go a long way as I am paying for them myself. Id like to add I've never been to welding school and thought long and hard about it but I don't know if it would pay off seeing as I've heard bad things about Tulsa welding school but am open to ideas what are other good schools out there I need to keep my current job and possibly go at night. What would be the best way to go maybe start out at a union? Also I used a keyhole dip technique for pics i provided what type of techniques are standard I know there lay wire and back feed thanks to Jody at welding tips and tricks. I'm just looking for some advice for what I need to do to get things rolling and how my roots are looking. Also what would be the proper way to remove the silicon along the toes of the weld. I normally weave 7018 after a single stringer there are a couple of pics showing a weave in a plate and then some stringers and some actual clips I welded on for a mezzanine per the drawing those are about 5/8-3/4 wide. I'm trying to get good at stringers. Maybe someone can post some pics of what I should be trying to achieve, the tig root has a few tie ins as well. Let me know what you think and what I should do to improve the welder is pictured so you can see the amperage. The photos are turned for some reason but everything is vertical up.
    Dec 2015
    Re: Tig root critique and advice.
    More pics
    May 2010
    Port Orchard, WA.
    You will have to pass a 6-G test. I suggest you buy a length of 4” sch 80 pipe, and a length of 6” sch 80 pipe. Bevel 37 1/2 degrees, and start welding. With a 6-G Tig test you have to be able to weld with both hands.
    Donít pay any attention to me
    Iím just a hobbyist!
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    Jul 2014
    MetalTown, USA
    You will have to pass a 6-G test. I suggest you buy a length of 4Ē sch 80 pipe, and a length of 6Ē sch 80 pipe. Bevel 37 1/2 degrees, and start welding. With a 6-G Tig test you have to be able to weld with both hands.
    The alternative to this would be going to the local shops and offering to buy their scraps. I cut my coupons 2" long for practice pieces. My shop routinely throws out 24" pieces of 10", 8", 6", 4", 3.5" and 3" pipe ... sch 40 and sch 80.
    We do a lot of structural columns and in the last year the shortest piece i have done with pipe was around 48".
    Or you could buy some 2 1/2" OD x 5/8" wall thickness tubing and practice monster coupons for unlimited thickness and and diameters down to, i think, 1". If you can weld small diameter stuff, you weld large diameter.
    AWS CWI xxxx2171
    1968 SA200
    Quote Originally Posted by WelderMike
    I hate being bipolar, It's awesome.
    Quote Originally Posted by ZTFab View Post
    Nice work!
    Visit Regulator and Torch Exchange, Inc. for all your cutting and heating needs!
    Dec 2015
    Thanks for the replies sorry I wasn't clear in the first post I know I need to pass the 6g and welding with both hands on tig isn't as hard as stick because I usually prop on something. If anyone has some pics of what I'm referring to please share so I can emulate them possibly with a coin for size reference and please tell me what you think about the pics. Thank you for the replies
    Dec 2015
    I bought 2 pieces of 20' 6x3/8 flat bar for 150 bucks how much would pipe be?
    Nov 2012
    Judging by that last pic, you're too cold. Weld hotter and you won't get those wagon tracks. Not sure if you're dipping on purpose, or it just turned out that way, but you don't really want to or need to dip a root on carbon steel.
    It looks OK for starters, just need practice time from what I can see. Looks better than some of our apprentices' welds.
    Dec 2015
    Yes I was dipping I know the lay wire would look better as I can do that no problem but if there's an uneven gap I want to be prepared. I was welding around 95 amps 1/8" gap 3/32 rod er70s2 I'll try hotter but it seem I get flat roots when I do that and I'm trying to achieve some protrusion on the inside as to prevent suck back any tips or fitup advice is greatly appreciated.
    Nov 2012
    Everybody that replies is gonna tell you something different, gap and wire and land, etc. Turn it up hotter and feed more wire.
    Dec 2015
    10 4 ive realized that feeding enough is one of the keys I will do that.
    May 2010
    Port Orchard, WA.
    Welp, Iím just a hobbyist welder!
    For the root I use the lay wire technique. I like a 3/32Ē gap, about 1/64Ē land. I use 1/8Ē filler, anywhere from 90 to 100-amps. For the hot pass I use 3/32Ē filler, and never go up more than 10-amps. This prevents suck back. I like a very sharp tungsten, with a # 7 cup with a bevel ground on the cup. That makes it easier to walk the cup.
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    Dec 2015
    Yep that one is a good if the fit up is right I just want to be prepared for the worse.
    Dec 2015
    Deleted
    Dec 2015
    Cep I don't believe you're a hobbyist would you mind posting some pics with something as a side reference for the root protrusion and width plz possibly include 7018 as well thank you for the fit up specs.
    May 2010
    Port Orchard, WA.
    Quote Originally Posted by leeroy86 View Post
    Well Ií am a hobbyist.
    I donít really have any good side view pictures of Tig welds. This is about as good as I have. Iím not real good at taken pictures.
    Also a 7018 weld.
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    Dec 2015
    What kind of hobbyist are you? lol looks good what kind of protrusion do you look for on the inside of the pipe? What about the silicon islands on the face of a tig weld you wouldn't normally weld over them would you so how would you remove them.
    Dec 2015
    By the way that pipe weld did you walk the cup or free hand the cap that looks awesome how wide and tall is the bead?
    May 2010
    Port Orchard, WA.
    Iím the kind of hobbyist that spends a lot of money on my hobby.
    The amount of reinforcement of the root bead is a 64 million dollar question. I guess it all depends on the code youíre working to.
    I use a wire wheel on a 4-inch grinder after every weld I make.
    99% of the time I walk the cup on the root pass. Free hand for the hot, fill, and cap.
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    Dec 2015
    I still don't believe you're a hobbyist those welds and tools you list aren't what a hobbyist would have lol. How wide and tall is that cover pass weld?
    May 2010
    Port Orchard, WA.
    Oh I donít remember! That was done a long time ago. I think that is 2 1/2Ē pipe.
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    May 2010
    Sparks, NV
    It's a bit of an inside joke, but he's retired from the industry and as he doesn't get paid to weld anymore, he is a hobbyist .
    Sent from mobile. Not responsible for Typos
    Jul 2014
    MetalTown, USA
    i run a 5/32" gap with no landing and 1/8" filler. usually around 85 amps. i run the hot pass at the same amperage as the root to prevent suck back.
    i agree your root looks cold.
    AWS CWI xxxx2171
    1968 SA200
    Nice work!
    Jul 2014
    MetalTown, USA
    last time i priced out pipe ...
    2 1/2" SCH 80 was around $250
    6" SCH 80 was around $550
    AWS CWI xxxx2171
    1968 SA200
    Nice work!
    Dec 2015
    So you're doing a keyhole dip then do you keep the tungsten pointing at the opening or do you wash the filler up on the bevels and share any pics of you have any plz.
    Dec 2015
    Lol ok makes sense that's awesome I would love to pick his brain in some things
Page generated in 1,632,681,959.71569 seconds with 12 queries
