Fabrication gloves
5.5K views 17 replies 8 participants last post by  Brazin
Hey guys I'm sure this question has been asked multiple times but here it is again. I'm working a sheet metal fabrication job at the moment and while the company provides gloves for you there's alot to be desired. They're thin and sometimes when I'm running high voltage spray MIG I can definitely feel it. Not to mention they're rather easy to cut through and there's alot of opertunitys to cut through. I'm going through about a pair a week and they don't really fit real good on me either. I'm looking for the best all around fabrication glove that resists cutting but I can still MIG and TIG with them. They also have to be oil resistant because all out steels coated in oil. Any suggestions are greatly appreciated. Thanks.
#2 ·
Any glove from miller, or black stallion should work for you, I used mig gloves for tig when I first got started there thicker which helps with the heat and more resistant to abrasions.
#3 ·
You should not be using the same gloves you handle oily metal with and tig welding with the same gloves.
I have like 3 or 4 pair of gloves in the shop. some for tig only, a pair for mig, a pair for stick and others for just handling metal, Oh and I keep a pair in my back pocket all the time for the unexpeded.
#5 ·
I mostly wear nitrile gloves in the shop because mostly everything is oily or dirty as hell. No problems with cuts. I think the leather glove is there for the accident not so much to have a guy think he can be careless with them on.
I never owned a pair or used one either but am really impressed with miller mig gloves. They are a joy to just check out.
I wonder why they don't want you to clean the metal, for sure it would make your welding easier to the point where I would probably say to hell with it and clean the material.
#6 ·
My shops all about getting the piece out to grinding who cleans it then to powder coat and finally assembly as fast as possible. Cleaning takes too long and they figure you can weld right through it no problem which we all know it doesn't work that way but they believe it does. Really I don't get much porosity or anything that often only every so often when its real dirty then I'll run a rag over it real quick to take the dust and some oil off.
#10 ·
I'm with you on that, all my life I have worked without gloves and taken plenty of flak over it. As a teenager I worked as a landscaper and one thing I learned, if you wear gloves you will need gloves. My hands got tough and if I tried to wear gloves I was too clumsy. Of course I wear them for welding, and for razor thin sheet metal work, but that's about it. Oh and on my job as a sparky I wear them on the rare occasion I do energized line work.
#13 ·
I am also bare handed most of the time but when I do wear gloves, I wear Mechanix high impact versions. I will do 95% of my torch cutting and MIG welding with them. Certain times if I feel to much heat when I'm welding, I'll switch to the heavy ones. Usually never a problem with the torch.
#16 ·
Concertina wire gloves if you really are working with sharp edges. I am always wrong about things but in my opinion and apparently nobody else where I work thinks this way. It is the persons job that is cutting the stuff to deburr it. I don't find any logical way around that to the point where I stopped deburring other people parts and just ship the stuff out that way now.
