Results 1 to 6 of 6
Thread: Brackets for 90 degree clamping ?? --
    Hi ...
    A while back someone posted where they had made some Brackets for 90 degree clamping out of 1/2" thick Alum. .... kind of like a stepped "L"
    Can someone help me find that post ?? I did search - but came up empty ..
    Thanks ...
    Welder want-to-be !
    Sep 2009
    Sedona, Arizona
    Re: Brackets for 90 degree clamping ?? --
    fabricationjunky.com
    he is under @arpcustomz on instagram
    Hey Jimmy,
    Thanks for the info above ... they look very useful ... I will probably order a set .. as a new fabricator I need all the help I can get ....
    But ... what I was referring to was ones similar to below ...
    Welder want-to-be !
    Sep 2005
    Cave Creek AZ
    As fabrication company, I can't see much use out of those stepped angles. You would be better off just making some 90* angles out of angle iron and plate similar to the fabrication junky angles. I also use the Bessey and strong hand 90*clamps quite a bit, they work well.
    Oct 2013
    Long Island, NY
    Big fan of strong hand. I only own one of the 3 axis, I want to get at least 1 of the 2 axis but I would love to have 4. Theyre pricey especially for the 3 axis.
    www.FirehouseFabricators.com
    Zach
    Lincoln 210mp
    Lincoln SW200
    Hypertherm Powermax 45xp
    2x4 CNC Plasma Table.
    North Georgia
    I just made my own with some strong angle iron. Picture a triangle, but with the very tip chopped off.
Page generated in 1,632,257,614.28329 seconds with 14 queries
