Results 1 to 7 of 7
Thread: Cool old Hobart MP 300 motor drive torpedo welder
    Mar 2015
    I picked up this old Hobart. It is a 10 speed model, with high 280 to 450 amps. Any current has three different gear settings possible, so I imagine the arc voltage will differ depending on what part of the range you are using. The fine adjust plugs into the center of the selector dial and can be connected with an old style 2 wire 110V extension cord to serve as a remote. The motor is listed as 20 hp 3 phase.
    The little bit I've used it the arc is sweet as a Lincoln motor drive.
    Does anyone have a serial number chart for manufacturing date?
    Name:  hobart mp 300 motor drive generator welder.jpg
    Jun 2010
    northern cal.
    Re: Cool old Hobart MP 300 motor drive torpedo welder
    The old Hobarts were tough birds. Built to last.
    MS
    Looks like it is really good shape. I saw one going for $875 I think a couple days ago and it did not look as good as yours.
    SA-250 TMD
    Squarewave 200
    Thunderbolt AC/DC
    1951 G.E. welder
    Ceres, California
    The year should be the two numbers before the W in the serial number.
    Go to www.hobartwelders.com and ask them.
    Sep 2009
    Cleveland, OH USA
    That is a motor \ generator type welder. You will need 3 phase 240 or 480 power to run the huge motor that turns the generator.
    Century AC/DC 250 Amp & Midstates 300 Amp Industrial AC stick welders, Century Flux core 80 amp. wire feed welder Harris Oxy-Acet. cutting & welding outfit:
    SEE MY INFORMATIVE VIDEOS AT http://www.youtube.com/user/alpho52
    Sep 2009
    Cleveland, OH USA
    Quote Originally Posted by Alphonse View Post
    The 10 settings are amperage ranges example 1 = 15-50 amps 2= 55-90 amps and so on up to 10= say 190-300max
    Aug 2009
    western new york
    Nice machine! Not as efficient as a new inverter, but much more character.
    IAMAW Local 330
    Airco 300 AC/DC Heliwelder
    Airco Dip-Pak 200 with Profax spool gun
    Powr-Kraft AC225
    Everlast PowerArc 200st
    Buffalo Forge No.21 drill press
    Speedglas 9100xx
    Airco, Oxweld, Purox, Victor torches
    Lincoln Ranger 8
Page generated in 1,728,037,186.68254 seconds with 19 queries
