Page 4 of 22 FirstFirst ... 2345614 ... LastLast
Results 76 to 100 of 543
Thread: Some everyday railings (and other cool stuff)
  1. #76
    Re: Some everyday railings (and other cool stuff)
    So that's how folk get double posts . disregard.
  2. #77
    Metalman23
    Nice work. You did a great job on those laterals. They cab be tough to try balusters and post in the same plane.
  3. #78
    Ct
    Quote Originally Posted by Rmac5 View Post
    Those are some awesome rails and gates. How do you fasten the post to the rock or concrete? Are you drilling through it?
    What do you find is the most effective method to fasten any of your rails to the structure or ground? Thanks for any help!
    Please post more pictures of your work
    Thanks! I use a hilti core drill, and use anchoring cement which is a type of hydraulic cement, which is my favorite method, it's actually sturdier than going into the ground 24-30" with a footing
    Metalman23
    Thank you sir
    More pics to come
  4. #79
    Ct
    This is how I weld the cast iron caps to the steel posts, no problems, it spits a little when your welding to far over onto the cast but it works perfectly
    My welder sneaked into the picture....
  5. #80
    Jan 2016
    Thanks for the follow up! Good to know.
  6. #81
    For what it is worth. I weld caps on occasionally...if I think it might be used as a handle. However, I prefer to use adhesives on many caps and finials. Adhesives allow the post and cap to be thoroughly painted. I think it also keeps the appearance of the two individual elements. Use of adhesive also allows the placement of cap at anytime after other welding is complete.
  7. #82
    Ct
    I really like that idea, I might try it sometime
  8. #83
    Ct
    Here's he job I finished today, about 54' of pool fencing with a double gate.
    I couldn't finish yesterday because I forgot my welding helmet , and my tweco fabricator 141i stopped working (yes I would've tried without a helmet)
    So I had to make 2 trips halfway across the state instead of one
  9. #84
    Ct
    Hey guys, I'm back after awhile, work is crazy right now, don't have much time to post
    But here's a big railing job I'm working on in greenwich, theres over 200 feet if railing, and about 14 feet of radius
    I'm behind the ball in this job, but I'm pulling in some people to help out and get it done
  10. #85
    Jul 2010
    Ogden, UT
    You do awesome work. I really like the entertainment center and the art deco ish gate.
    Great job
  11. #86
    Ct
    Quote Originally Posted by engineer1984 View Post
    Great job
    Thanks! I've been sooooooo busy I feel bad, haven't had much time to post pics to this thread, but do not fear, I will update you guys with my latest railing jobs.
    Sent from my SAMSUNG-SM-G890A using Tapatalk
  12. #87
    Ct
    Check this out, I got a job at a local bank, making some aluminum ADA handicap rails, I mig welded 1-1/2" SCH40 6061 with my spool gun, then sanded it with a D/A sander, 60grit to give it a satin sheen, I didn't have the time to order an elbow for the return so I just cut and welded my own return (which I think looks pretty cool)
    On site I stick welded the sections together, I'm seeing the benefit of having aluminum electrodes on the truck, way faster and simpler than bringing my TIG and running it off the welder. With a little practice one can run a decent uphill bead with these aluminum rods.
  13. #88
    Jul 2011
    Railings look nice man. Good on you for running aluminum stick rod for something like this. Not able to interface your spool gun with your gen? My 30a ran nice off my trailblazer haven't run it off the bb500 yet but I imagine it runs every bit as nice.
  14. #89
    Ct
    Quote Originally Posted by KD Welding View Post
    Thanks, I can't figure out how to interface my spool gun, it's a ST-23a, I'd love to do it but need a control box of some sort
  15. #90
    Ct
    Far as I can figure, I just need to make a DC power source to power the spool gun motor, hooking up the leads is simple enough
  16. #91
    Ct
    Don't know if I posted his already, here's a sculpture I made for a customer last year
  17. #92
    Ct
    Here's 2 gates I'm working on today, the same as the one I made earlier this year
  18. #93
    Ct
    Here's the radius stuff I been working on last couple days, it's part of a larger job, 292 linear feet total.
    Here's the jig I set up to make the 11" wide decorative panels, made with 1.5" posts and 8" circles.
    Heres a panel clamped down to the table ready to be welded out. I had a lot of trouble figuring out how to control the warpage on these panels, took me 2 or 3 days to figure out the order to weld the joints to eliminate warpage.
    Here I'm rolling the horizontal members with my HF roller (soon to replaced with a real roller)
    And here you can see my jig for setting the picket spacing, which are 3/4" solid square.
    And here's a good view of a panel clamped to the 39' 5" radius form that I built.
  19. #94
    Ct
    I'll post some pics of the final product when I go to the job, I'm not installing (thank God)
  20. #95
    Nice work
  21. #96
    Jan 2011
    W. Wisc
    Impressive! What is the problem with the HF tubing roller? Not holding up? Need a powered one? Curious...
    -Dave
  22. #97
    Ct
    Nice work
    Thanks!
    It has too much slop, it tends to curl or twist the piece you're rolling. So the piece ends up bent in two axis instead of one.
  23. #98
    Sebeka and Bemidji MN
    I really like your work, looks great
    Having that roller twist the piece would drive a man to drinking
    Syncro 350
  24. #99
    Feb 2016
    East Texas
    MetalMan, your work looks awesome!
    Forney C5 Arc Welder
    Lincoln Idealarc 250-250 Ac/Dc Arc Welder
    Miller Bobcat 225g Plus
    Lincoln PowerMig 200
    Forney O/A Rig
  25. #100
    Nov 2014
    Nice work man. Most of what I do is handrails also. I like your ideas and creativeness. I have one of the HF rollers also and got the mod kit from SWAG Offroad to turn it into a power roller. Works pretty good.
Page generated in 1,627,075,465.75399 seconds with 12 queries
