Which air dryer/filter for the Hypertherm Powermax 45
7.8K views 19 replies 13 participants last post by  CEP
Well I am finally pulling the trigger today on the 45. The thing I need help with is which dryer/filter I need to get. I've searched and read a lot of threads but can't find a definite answer. I've been running and in-line water separator on my Lotos and haven't had any problems but I want to take care of the Hypertherm, it needs to last me a lifetime (at least in dog years). If it helps its not a commercial application, only small shop use. And yes I know its overkill and I could buy a cheaper brand and get by but sometimes in life you just get to go for it and have the best which is rare for me, hence the desire to really take care of it like I do my other tools. Any help is appreciated.
Oh, and this is my first post I'm new here. Really glad to find it, great site. I'll go and do an introduction
Roy
#4 ·
Another big help, is to build an inner cooler, and after cooler. Some copper tubing in a garbage can filled with water, or ice works great.
#5 · (Edited)
Not to hijack this thread but that after cooler CEP showed would be a great way to cool a water cooled TIG torch. I think the large garbage can is a bit overkill tho. My guess is a 5 gallon bucket would work.
BTW, to cool a TIG torch you would run water thru the copper instead of air of course.
#6 ·
Nice cooler CEP!
I have a refrigerated dryer which does a great job. I picked it up off CL years ago for $100. I found that putting an electric auto-drain on my tank really cut the amount of water that reached the dryer.
Here's an old thread that has some photos of my setup.
http://weldingweb.com/showthread.php?47000-Air-dryer-for-plasma-cutter
The most important thing you can do to drop moisture ahead of your plasma cutter has to do with proper plumbing practices. Small hoses/lines keep moisture in the air. Large lines move at a lower velocity and drop water. Years ago we were hooking up furnaces at the farm. We temporarily ran an air hose on an overhead cable between two builds. As a result, water collected in the droop of the hose and froze solid. Lines should have slope back to a drain point. Pull air off a tee rather than the bottom of the drop. Put a valve at the bottom of all your drops to drain any water that may collect.
#14 ·
#9 ·
#12 ·
Pretty sure the M-100 is the kit with an M-60 and two filters.
I prefer the M-60 over the M-26 for fixed/rigid applications since it has 1/2" MPT ports instead of 1/4" (good for quick connects).
It uses the same filter but has a slightly higher flow rating. Both flow ratings are far above what the PM-45 requires.
#15 · (Edited)
I use a Motorgard M60 filter into a campbell hausfeld desiccant filter then into the PM45
The internal water trap on the PM has always been spotless.
BTW,
you can also use the PM30 consumables on the 45 .... it gives you a finer cut for thinner material.
( the PM30 .... NOT the PM30xp)
#16 ·
BTW,
Thanks John T, didn't know that about the consumables, great news
Sent from my SM-G920V using Tapatalk
#20 ·
Yes there was, one to drain the copper tube, and one to drain the garbage can.
The drain for the copper tube, I always opened it first, to blow the water out.
#18 ·
Where do you live? This matters if you are in a humid climate....if in a desert climate with low humidity, and you are using a Powermax45 you will not need any additional filters or moisture removal devices. The 45 has a built in particulate and coalescing filter with an auto drain.
If you live where humidity is high, then an auto drain on your compressor is a must. A 20' length of copper pipe (downstream of your compressor) with a down-leg and a coalescing moisture filter at the end (lowest point) will work for most of the moisture. That may be adequate.
If you are high humidity and do a lot of cutting (more than typical hobbyist) then the best solution is a refrigerated dryer.
Many put too many filters, dryers , etc on their plasma system and create air starvation (every filter will drop some pressure under flow conditions.). Always install a pressure gauge after all filters, hard plumbed at the plasma air inlet. Monitor this pressure when air is flowing at the torch....for a Powermax45 the flowing inlet pressure must be above 90 psi and below 120 psi for best results.
Best regards, Jim Colt
