Results 1 to 23 of 23
Thread: 250 VAC 50 amp - generator adapter plug?
    Feb 2016
    Hi Guys, i'm a total noob here so if i'm asking the wrong question, please feel free to educate me.
    i have taken a few welding classes around town and done a couple of projects, using a local shop near me, but the shop time is adding up so i'm putting together my own equipment.
    I recently purchased a chicago electric mig 180: http://www.harborfreight.com/180-amp...der-68886.html
    i'm no electrician, let me be clear on that. it has a 2 prong "220" plug, i believe, looks like a standard 110 volt outlet, only larger.
    page 6 of the manual has relevant information: http://manuals.harborfreight.com/man...8999/68886.pdf
    So, my intention is to get a generator to power this, but when i look at generators, none of them have a matching female plug, so i'm thinking i need an adapter, but before i drop the money on a generator i want to know that it can handle the load.
    at one point in the manual, it says "250 VAC and up to 50 A" and at another point it says "Power Input 240 VAC, 24 A"
    when i look at generators i see a couple of types of 4 prong outlets, one is like my plug but an extra input, another is circular... and they tend to say "240 v 50 amp"
    will a generator that says 240/50 meet my needs, and are there adapters i can get? or, do i need to find a generator with the specific plug i already have?
    lastly, i've noticed that generators are advertised by wattage, what would be the minimum i should look for to fit the machine i have?
    thanks in advance
    matt
    Re: 250 VAC 50 amp - generator adapter plug?
    You will need an adapter. If your gen has a 4 prong ( like yours but with an extra prong then you can buy one premade from several welding companies. If you get a gen with 50amp twist lock then you will probably need to make your own. Th extra prong is a ground. 2 hot wires a nutral and a ground.
    Los Angeles
    5500watt RATED generator minimum- which is usually about 6500w max.
    The HF machine will draw 24amps.
    http://weldingweb.com/vbb/showthread.php...tor-(pictures)
    MM211 (Sold)
    Klutch 120v Plasma cutter
    Nov 2015
    Beacon and Pawling, New York
    I just looked at the specs for my generator. 7500 watts rated, 8500 watts peak will give 62 amps 120 volts and 31 amps 240 volts. The recepticle is labeled 120/240 30amp. So if you want 240volts and 50amps from the generator, you're going to need a big generator
    But your current welder should run off of 7500/8500 watts.
    Eventual master of the obvious, practitioner of "stream of consciousness fabrication". P.S. I edit almost every post because because I'm posting from my phone and my fingers sometimes move faster than my brain.
    Dec 2011
    Kentucky
    with out pictures it's hard to say what you need
    The Manual for your welder ask for a 6-50r receptacle
    you stated in your post that the welder had a " 2 prong plug "
    Haven't seen on of those in a while - most have 3 prong
    your welder pulls 24 amps or 5760 watts
    The main thing is not to panic or get excited
    Bobcat 250, X-Treme 12VS, MM211
    Meltabo, Milwaukee,Porter Cable,Dewalt,Makita
    Victor O/A, Ingersoll-Rand
    Evolution Rage2, 40 amp Plasma
    Lincoln 225 AC/DC
    Dec 2011
    Kentucky
    most small generators that have a 240v receptacle will be like this pic
    the post above by mr broccoli1 references another post here on WW
    that will show you how to make an adapter for your welder
    Lincoln 225 AC/DC
    Northern Cal., Shasta County
    The rating stamped on an outlet whether in a building or on a generator doesn't mean much. Means that it is stamped by the manufacturer to handle anything up to that amount. What it is wired for/what is feeding it is what is important to note. On a generator there needs to be a notation along side the outlet that states it provides xx amps or documentation stating that it provides xx amps. An example would be a genset with a twist lock rated for 30 amps but the gen feed to that out let is 23 amps.
    Nov 2015
    Agreed. My point was that no adapter, however confugured , was going to plug into that twistlock and provide 50 amps.
    Feb 2016
    thank you everyone for the replies, i think i have my answer now:
    if my generator has a 4 prong straight 240v outlet, i can get an adapter. if it has a twist lock, i will need to build one.
    and, my welder pulls 24 amps, the 50 is not relevant. for my generator i will need one rated above 6000 watts.
    thanks again to everyone!!
    matt
    Dec 2011
    Kentucky
    your welcome
    it's not as hard as it sounds - couple screwdrivers
    a piece of wire - a pair of pliers & a good pocket knife
    will make any adapter
    Lincoln 225 AC/DC
    Long Island
    Quote Originally Posted by Renagade View Post
    your welcome
    You're right as to what tools are required. But as to the difficulty, I'll put it this way:
    I've made many hundreds of plug ends (that see continuous use and abuse year after year), and never had one I made fail.
    I've re-made dozens of ends done by other people (many, made by master electricians).
    Two tips for success.
    1) Use the strip gauge that comes with the instructions (unless you really know what you're doing). Most people tend to strip too much of the jacket, and then the clamp grabs the wires instead of the jacket (that's bad).
    2) Be VERY careful when stripping the jacket to not nick at all the wire insulation. Rubber insulation tears very easy where damaged, and the slightest nick into the individual wire's insulation from the knife is a huge issue. What I do, is score lightly all around the jacket, then bend the wire around the score line to start it to open up and tear, and carefully use the knife in the sections between the wires (where it's a little safer to cut) to help it split all the way around.
    Arizona
    Quote Originally Posted by rlitman View Post
    I do the same except I cut a ring around the insulation with Blue Kleins then I bend it then pull the rubber off. I also use Hubbell cord caps, they are the best and hold up to job site abuse.
    Miller Challenger 172
    Miller Maxstar 150 STL
    Victor 100C
    Victor Journeyman
    Oxweld OA
    Harris O/A
    Smith O/A little torch
    No, that's not my car.
    Long Island
    Exactly. It's all about the bending and pulling, and not cutting.
    Yes, Hubbel makes the BEST stuff.
    Feb 2016
    stop the presses! (always wanted to say that)
    would this not be what i need?
    http://www.amazon.com/Conntek-PL1430.../dp/B00SSQIY4M
    Los Angeles
    Yup.
    But you could make one cheaper with a longer cord.
    MM211 (Sold)
    Feb 2016
    understood! but, for the power level we're talking, if i can trust someone else's electrician skills, i may just choose to pay the premium.
    thanks broc, renegade, sedan and all the rest! you guys are awesome!
    matt
    Los Angeles
    MM211 (Sold)
    Jun 2016
    Quote Originally Posted by stuckym44 View Post
    matt
    Di you purchase the plug adapter or custom make one, im in the same pickle. I bought a harbour freight generator rated 8000w and the chicago mig/flux rated 180amps. However it has a twist lock 4 pin on the gen for the 220. The plug on the mig is a 3 pin. Can anyone point me in the correct direction of building an adapter. Premade adapters are rather expensive and im not sure of the items quality either!
    thanks
    Nov 2015
    Use the diagram in post #6 to wire your adapter. You won't use the neutral. The two 120 volt legs add up to 240 volts. Attach your ground (green wire) to the plug with the bent leg and each of your hot wires to the terminals on either side of the ground. You will not use the neutral from the generator. Connect your green wire on the recepticle to the ground terminal (half round pin) connect your hot legs to the other terminals.Select beefy wire. 8 guage would be my choice for this particular application. If you were hooking to a 50 amp source, 6 guage.
    Nov 2015
    Just buy a heavy duty generator cord and cut the recepticle off and then you only need to wire one end.
    Laredo + Midland/Odessa
    Dang that's expensive!! I used this one:
    https://www.amazon.com/gp/aw/d/B0000..._1465405981646
    Together with this one:
    http://www.usaweld.com/50-Amp-Electr...le-p/12543.htm
    Some 6awg wire, and you have one awesome adapter.
    Los Angeles
    6g wire is overkill. The connector for the genset side is only 30amps.
    as mentioned buy a genset cord and replace one end.
    http://www.harborfreight.com/25-ft-x...ord-62308.html
    MM211 (Sold)
    True but over-killing things is under rated, lol.
Page generated in 1,713,241,035.38777 seconds with 19 queries
