Results 1 to 23 of 23
Thread: Simple shop made tungsten grinder
    Jun 2011
    Eastern Washington
    I was looking at some of the dedicated grinders for tungstens, and realized that there was a simple and inexpensive way to make one from a spare moto-tool, some scrap aluminum I had from another project, and some cheap diamond cutting discs.
    The moto-tool has a cap at the end that is threaded 5/8-12, and I figured I could build a grinding head that would screw on in place of that cap.I turned , bored and then threaded the part that would thread on to the moto-tool, and then threaded the end for the grinding section(I buggered up my first attempt and rather than starting over, I built it back up with the TIG and re-cut the threads.Boy I love doing stuff twice.NOT!!!)
    Name:  tung grind 4 - Copy.JPG
    I turned, bored and threaded the grinding section, then I drilled 4 3/32" holes(This is the size tungsten that I mainly use) at 20,25,30,35 degrees to the grinding wheel and intersecting the wheel in the middle of the abrasive portion of it.I left the walls of the grinding section pretty thick so as to give the tungsten as much support as possible and to add a little weight as I use it standing upside down( This way the dust settles into the cap not around the tool shaft)
    Name:  tung grind 3 - Copy.JPG
    It only takes a few seconds to grind a new tip on the tungsten and the angles are repeatable and accurate.If I find that I want a different angle or if I start using different sizes more I can always drill more holes to get what I want.
    Here are a couple more pics of the assembled grinder and its components.It isn't pretty, but it functions well and that is all I really care about.
    Hope you find this project interesting.
    Name:  tung grind 1 - Copy.jpg
    Name:  tung grind 2 - Copy.JPG
    Name:  tung grind 5 - Copy.jpg
    Jun 2011
    Eastern Washington
    Re: Simple shop made tungsten grinder
    Here is a better pic of the different angles I ground on some tungstens with this grinder for a test.
    Name:  tung grind 6 - Copy.JPG
    May 2011
    That's a great idea. Brilliant
    May 2011
    wisconsin
    i was trying to come up with something similar . great idea and nice build!
    >Innovations are what i leave behind for History<
    Feb 2010
    Ocean Springs, MS
    wow thats slick dude !!
    Dec 2009
    Stevens Point, WI
    Thats excellent!
    Jun 2011
    Eastern Washington
    Thanks.
    The hardest part of this project was determining how to drill the holes so that they would hit the wheel at the required angle and in the center of the abrasive part of the wheel.I also wanted to make sure that the tungsten hit the wheel at as close to a right angle as possible, that way the grinding striations were longitudinal as possible and ,so they were facing into the rotation to help minimize burrs on the tips.I drew it up on TurboCad and then carefully laid them out on the piece, then used a digital angle gauge to set the piece up in the vise, milled a flat spot and drilled.Here is a pic of the tungstens in the holes so youy can see how they hit the wheel.
    Name:  Tung grind 7 - Copy.JPG
    Feb 2010
    Pittsburgh
    i'd buy one if you sold it
    ESAB MigMaster 275
    Miller Econotwin HF
    Miller Syncrowave 250
    Jan 2010
    Central IL
    A very simple, cheap and easy to use sharpener can be bought from..............I hate to say it...................Harbor Freight! http://www.harborfreight.com/catalog...lade+sharpener
    Remove one guard that encloses the diamond wheel, chuck your tungsten in a drill and have at it. You can put any angle you want on very easily and can blunt the points if you want and use it to cut your tungsten to length.
    I've used one for about 2 years now and love it. Be sure to use a 20% off coupon!
    "The man of great wealth owes a peculiar obligation to the State, because he derives special advantages from the mere existence of government." Teddy Roosevelt
    American by birth, Union by choice! Boilermakers # 60
    America is a Union.
    Jun 2010
    Massachusetts
    that's pretty clever dude. nice idea
    ESAB Heliarc 252
    Jan 2008
    rotate the tungsten between thumb and finger ?
    Jun 2010
    Beautifull Downtown Bronson,Fla
    Much cheaper home version of the diamond grinds and others moto tool powered tung grinder. Have a beer or three with the cash you saved on a much better and nicer tool/ Thats a two thumbs up...
    Bob
    I'm spending my Kids inheritance, I dont like him that much anyway!!!!!!
    Enuff tools to do the job, enough sense to use em.
    Anybody got a spare set of kidneys? Trade?
    Oct 2010
    western kentucky
    you might refine the design and draw a blueprint of it, print a copyright on it and get a patent . you never know you might be able to sell a couple tons of them, and make a nice retirement fund.
    Sydney Australia
    Nice idea but just a few points
    The angle seems a bit obtuse , you want the taper to be about 2 1/2 times the diameter of the elctrode.
    Also are the grind marks running in line with the length of the elecrode? ... that also is important.
    A good guess is better than a bad measurement
    Pensacola , Fla
    Here is one I built older post. http://weldingweb.com/vbb/showthread.php?t=50085
    diameter of the wheel has a effect of length of point.
    very nice work on yours tool junkie
    Aug 2009
    Atlanta Ga
    ill send you $50 for one. if you put the correct angle on it.
    Oct 2010
    western kentucky
    yea it should be a verticla grind with a bit of a radius to it.
    where it would get a little hairy is after you got some wear on the cutoff wheel
    Oct 2010
    excellent, with no more to say.
    Feb 2009
    Chicago
    Can you make me one? Pm me a price. I would love to bolt this to the side of my welding table.
    Hypertherm Powermax45
    CK MT200 ac/dc
    Razorweld 195 Mig
    Razorweld 200ac/dc Tig
    Tormach 770, Tormach xstech
    Razorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
    Jun 2011
    Eastern Washington
    Quote Originally Posted by Brett View Post
    You are right I didn't get enough angle on the first holes so I drilled new guide holes at 10 and 15 degrees, and they look much better.
    I made sure that the electrodes hit the wheel at 90 degrees to the shaft so the grinding marks are running lengthwise with a slight radius.
    Oct 2010
    Fort Collins, CO
    Quote Originally Posted by brucer View Post
    opps...public disclosure no patent to be had here
    BUT...looks like plenty of interest regardless. may have to build one soon! looks like a good excuse to hook of the 4th axis on the mill.
    Feb 2009
    Chicago
    How much?
    CK MT200 ac/dc
    Razorweld 195 Mig
    Mar 2006
    Yuma, Arizona
    why are we bastardizing HF tools? you would think by now that HF actually has a tungsten grinder, no?
    The copy everything else. They might as well.
    Lincoln Power Mig 210MP MIG
    Lincoln TIG 300-300
    Lincoln Hobby-Weld 110v Thanks JLAMES
    My brain
Page generated in 1,623,670,090.49018 seconds with 12 queries
