most welders in USA if asked do they prefer or like to use 6013 will say no, which i kind of wonder why. some welders look down on 6013 and call it farm rod.
now i got over 35 years experience using 6010 and 7018 and mig welding and was certified for structural welding with 7018 for over 15 years. not like i cannot use 6010 or 7018
since i had broke my leg at ankle i had time at home to play in garage welding. so bored, i practice with 6013 instead of 6011 or 7018. of course i get occasional slag islands and other problems at times, but being stubborn i practice some more with 6013. welding handbook says use 3/16 6013 rod at over 200 amps on over 1/8" thick steel is maximum limits
i go buy some 5/32 6013 at Tractor Supply seeing how welding store does not carry 5/32 6013 rod anymore. So i practice on 3/16 thick steel with 5/32 6013 rod at 120 to 145 amps. actually not easy to be able to handle the bigger rod at relatively high amps at the much faster speeds. book says manipulate rod angle, arc length, travel speed and hot whip to try to control as well as dwell and circle a bit at arc start to avoid weld start slag entrapment. hot whip or back and forth in direction of travel but maintain short arc length has its limits with 6013 to avoid slag entrapment. anyway i make a 2x2x3/16 angle bracket 36by36 with brace and at least one mitered corner of 45 degree cut ends. actually hard to do and make welds look like done with 7018 or flux cored mig
basically i did it for the challenge of using 5/32 6013 on 3/16 thick angle and actually getting all the welds to look good and no slag entrapment or bad looking spots. not perfect but not bad looking. it is actually in my opinion harder to get good looking welds with 5/32 6013 at high travel speeds compared to using a small say 3/32 7018 rod or a even slower 1/8 6011 rod. kind of hard to keep up with 5/32 6013 rod on 3/16 thick steel.
just wonder on other opinions does anybody prefer using big 6013 rod ?? ....... i have occasionally seen fans and pump bases made of 1/4 thick steel with big oval circle welds (high travel speeds) which can be mistaken for mig flux core when it also looks like 3/16 diameter 6013 type welds at over 200 amps.
