Results 1 to 7 of 7
Thread: Powcon 300sm w/o feeder--good/bad
    Jan 2016
    Raleigh area, NC
    I have a Lincoln tombstone AC/DC (the little one, not idealarc).
    I know someone with a Powcon 300sm, but no feeder, under $300. Is that going to do anything for me? I was thinking more for using it as a scratch tig box, but now and then a wire feeder comes up and might be compatible. I've held off getting a mig only because of limited space, and inverters are pricey. So maybe this plus a feeder gets me a 2-for-1.
    I know these were built well, but they are old. I figure won't outlast my tombstone. Is there any advantage over what I have now? Little lighter weight. Higher output & duty cycle.
    Also, the "power level" knob is strange vs. amps. Seems that would be hard to set.
    What I really want is an inexpensive HF starter so I can use low amps to stick weld thin stock. I know this doesn't get me that.
    Aug 2008
    Sudbury, Ontario
    Re: Powcon 300sm w/o feeder--good/bad
    I have used one in the past. One of the nicest arcs for stick welding I ever used. I was really disappointed when it expired.
    For you, definitely a step up from that Lincoln, not a lot of money and you can find a used feeder for it. I'd just get a suitcase feeder for it, Lincoln or Miller.
    SA 200
    Idealarc TM 300 300
    MM 200
    MM 251
    30a Spoolgun
    Precision Tig 375
    Invertec V350 Pro
    SC-32 CS 12 Wire Feeder
    Oxweld/Purox O/A
    ArcAir
    Hypertherm Powermax 85
    LN25
    Feb 2015
    Great welders, I would not hesitate to buy for that price. Almost any feeder will work and eBay always has some old Powerdrive 1 or 2's for sale that plug right in if you want to make it easy. You won't want to use the tombstone after you weld with the Powcon.
    Sebeka and Bemidji MN
    It's cheap enough - I'd buy it
    Syncro 350
    Jan 2016
    Raleigh area, NC
    Wow, unanimous. Thanks guys. Didn't know I would notice any difference in the stick welding, but then I've only used the tombstone so no comparison to anything.
    Jan 2016
    Raleigh area, NC
    Looks like the guy blew me off. Had a bad vibe about that one, anyway. I'll keep looking.
    Ceres, California
    Just about any 24 volt wire feeder can be used. You just have to add a relay to reverse the welder control from normally open to normally closed.
    The 200sm takes a closed switch to turn the welder output off. Change the plug to match the powcon.
Page generated in 1,624,031,096.07786 seconds with 11 queries
