Results 1 to 6 of 6
Thread: Plasma Cutter Wiring ~ Ground clamp plus grounded table possible?
    Apr 2016
    Hey everyone my first post here! I did some searching and did not find a clear answer before posting.
    I am trying to find out if I can have two grounds for my plasma cutter.
    1 of 2: The traditional grounding wire & clamp
    2 of 2: A bolted ground from my cutting table to cutter
    I am asking because I constantly go between an upright easel for cutting sheet metal, and also use my flat false bottom cutting table. I seem to forget to move my grounding clamp from work area to work area, and perhaps I could have my table always grounded to my cutter, while also having my traditional grounding clamp. Has anyone ever seen this or are there any complications here?
    I have a Victor Cutmaster 52
    Any opinions and suggestions out there are GREATLY appreciated, I'm thinking it would be relatively straight forward but I might be overlooking some safety aspect for me or the cutter.
    Thanks!
    Delaware
    Re: Plasma Cutter Wiring ~ Ground clamp plus grounded table possible?
    Sure you can.
    Apr 2016
    Thanks for the input!
    Nov 2015
    Beacon and Pawling, New York
    There's no such thing as "too much ground "
    Eventual master of the obvious, practitioner of "stream of consciousness fabrication". P.S. I edit almost every post because because I'm posting from my phone and my fingers sometimes move faster than my brain.
    Ceres, California
    I would go one of two ways. First put an inline connector.(dinze or tweco) and have two work leads and just swap them as needed.
    OR make one good connection to table then make the second work lead connect to the same spot. This way you have series connections and not parallel.
    By the way these are work leads. they are not grounds because they are carrying current.
    Jun 2014
    SE Oklahoma
    As stated yes you can and as stated never can have too much ground ... I even have a ground from my table leg to an outside ground rod
    Located In SE Oklahoma
    Lincoln Mig 135
    Hobart Ironman 230 Mig
    5x10 CNC Table with DTHC & FT
    Hypertherm PM65 on the table
    Miller Bobcat
    www.caneyagequipment.com
Page generated in 1,664,390,162.33868 seconds with 11 queries
