Results 1 to 25 of 30
Thread: Any advantages to a conventional flip helmet over an auto darkening helmet??
    Apr 2016
    I have noticed at college wearing my autodarkening mask it seems ok but when I'm a couple meters away from the arc watching others it flickers, it's not a cheapo one either it's make is "sif", I wondered if this was the auto darkening function, and also wondered what advantages a conventional flip helmet has over an auto darkening helmet
    Nov 2010
    Houston Pennsylvania USA
    Re: Any advantages to a conventional flip helmet over an auto darkening helmet??
    Pros and cons to both. It depends on what you are doing. I don't think I will buy another auto dark. It is a lot of fun trying to weld around a strobe light wearing an AD!
    Jul 2009
    SW Washington State
    Hello Ajh, it is certainly likely that when you are a ways away from a welding arc that your electronic hood could "flicker" (due to the sensors not being fully activated) and you are right, a passive hood will not. Electronic hoods are certainly a thing of beauty for many welding applications, yet not all. Most electronic hoods do not handle heat and cold well and can fail when put to extremes either way. Additionally, most electronic hoods don't handle moisture well and can either fail temporarily or completely when subjected to moisture. The electronic hoods are also very short-lived when they experience certain shocks or drops from heights. A passive hood doesn't necessarily fair too well either when dropped/shocked, but at least it won't put a huge dent in your wallet when something bad happens and you break a filter plate or cover lens.
    I should add here though, that when you are needing to hang onto something in order to tack it that auto-darks are the bomb. Also, if you are underneath your vehicle or in a tight place trying to make a weld that auto-darks again can come to the rescue and make your welding task much less stressful. I use both types of hoods and generally assess the situation and consider which will work the best.
    A lot of field welding situations are better addressed with a passive hood over an electronic due to the relative sensitivity to elements and in some cases jobsites will not allow use of an electronic hood for safety reasons (they feel that an electronic hood can switch to the dark shade at the wrong moment and subject the user to losing their balance and a host of other safety related items). I am sure that others will have additional things to add here. Common sense will go a long way with determining whether use of one or the other is warranted or a good choice. Good luck and best regards, Allan
    aevald
    Sep 2015
    SE Pa
    The arc flash probably isn't strong enough at that distance to keep it dark.The advantage is cheaper,always work different
    Color lenses .Disadvatage is if you are in a tight area where you can't flip your hood you are more or less blind
    Mar 2004
    Not having to whine and cry when your helmet falls off a scaffold.... You mates don't appreciate the tears as you tell the sad tale at coffee :'))
    Apr 2016
    Central KY
    I love my old shade 10 flip up, but then again im technology impaired. In my experience it's not worth the hassle of auto darking. I have just used a cheep auto darking helmet.
    Sent from my XT1585 using Tapatalk
    Jan 2011
    Mid-Atlantic, USA
    I know a guy in his early 50s who has "weldor's neck," which is kinda like tennis elbow, but it's caused by the repetitive motion of snapping fixed lens helmets down. Breaking an AD helmet that falls at a worksite is cheap compared to replacement necks. Have you priced one of those lately?
    1969 Chris Craft Roamer 46 Refit
    Miller TB280 w/Spoolmatic 30a
    2016 AHP AlphaTIG 200X
    Ancient Millermatic 35
    Zeny Cut50 plasma cutter
    Apr 2016
    Great guys thanks very much, looks like I need both sides of the equation, maybe a flip mask for college
    Apr 2016
    I prefer a auto when tacking or working sheet metal, if I'm burning lots of wire or rods all day long I use a passive with gold lense.
    Sent from my SCH-I545 using Tapatalk
    PNW
    currently i use an old speed glass 100 and a huntsmen 951 passive.
    i use the ad for all fit up and tacking, being able to tack four corners of tube/pipe without flipping a hood four times is more productive and less fatigue. when its time to weld out i often switch hoods but only when convenient. the ad is more versatile, and gets the most use, but i cant stand heavy weld hoods get the lightest ad you can (i really like the cheapest speedglass model)
    Nov 2014
    I use both, I have a Jackson balder I use for TIG welding thin stuff and when doing abunch of quick tack welds and a chopped fiber metal pipeliner with a shade 10 gold lens I use for stick, mig, and long welds. I prefer the fixed pipeliner and I use it for almost everything, just gets annoying for stuff that just needs abunch of tack welds and no beads.
    Jan 2015
    Pt Pirie South Australia
    No such thing as a dead battery with a flip
    Dec 2009
    Stevens Point, WI
    I love my flipper! I used auto lids, they flashed me, piss on that!
    The flipper never has dead batteries, never flashes you because you block a sensor, and can take a beating.
    1989 and hasn't needed a battery change yet!
    Jan 2016
    Indiana
    Quote Originally Posted by mikecwik View Post
    I gotta ask, why are you welding around a strobe light?
    Another note, ad rock, but a cheapo flip down makes the perfect backup.
    Sent from my 831C using Tapatalk
    Jan 2015
    Edmonds, WA
    Quote Originally Posted by Max Zubrenic View Post
    Heavy equipment sometimes have strobe lights on them for visibility, I actually just encountered this a couple weeks ago.
    Jan 2016
    Indiana
    Quote Originally Posted by Sharon Needles View Post
    Oh THAT kind of strobe. I was thinking more of a rave......
    Feb 2010
    Bandera,TX / MN
    I have both. Strobes are a pain in the *** and the battery will never fail on a flipper.
    Jul 2014
    A battery on an Auto dark will never fail if you change them once and a while.A slurrpy for the ride home cost more than a battey ,don't be such a tight a$$.
    Jan 2016
    Indiana
    Quote Originally Posted by gxbxc View Post
    Or get one with a solar panel and it'll last even longer!
    Jan 2015
    Edmonds, WA
    That's the way my Tradesman is set up, and I keep a shade ten passive filter in my hood bag as a backup in case it ever dies.
    Jan 2011
    W. Wisc
    Get the strobe lights on the equipment changed over to LED strobes. They won't trigger the auto dark lenses.
    -Dave
    Apr 2016
    Everyone's work environment and needs are unique and different.
    This one is nice. Fibre-Metal SUPERGLAS F706 Fiberglass Welding Helmet
    I had very mild seizures as a kid just enough to be technical. My medication has been fully controlling them for 40yrs now.
    Yet I personally feel the need to play it safe just in case.
    I personally chose and love my Kobalt 1/20000 sec 4 arc sensor with removable batteries auto darkening hood for the variable shade feature, plus I'm just learning to arc weld.
    At arms length simple sparker for a propane torch will drop its shade instantly.
    May 2013
    Puyallup, WA
    I've tried all the top-rated auto hoods besides Optrel and still definitely prefer any fixed shade. Auto darks are very handy if you do a lot of tacking, or have to hold something steady and the movement from flipping your hood will cause it to be off enough that you have to break the tack. They're also pretty handy if you do several different size parts regularly- I could go from .030' wall stainless to 1/2" aluminum in the same day and it's no fun having to swap lenses all the time. Favorite part about a fixed shade is if you drop it, it's not likely to break; and if it does, it's only a few dollars to replace it.
    "I fully know my place in life, and it's behind a welding helmet...." - Jesse James
    IG: @weldakota
    Dec 2009
    Stevens Point, WI
    I could see a welder being used to create "light" at a rave.
    Jan 2016
    Indiana
    Quote Originally Posted by VPT View Post
    You saw me when I was trying to run 6010 last week?!?
Page generated in 1,627,666,836.32061 seconds with 11 queries
