Re: Thermal Arc Fabricator 181i mig/tig/stick
When I said "Cigweld 200i" I meant it ~literally.
The color and the stickers are likely the only external difference, other than the probably new 110/220 auto line inverter board.
I'm just curious if that's the ONLY difference.
I'll probably want that 4" spool adapter sooner or later, I'll see if my LWS can get them...
The 181i has an 8 pin remote socket.
Can do wire speed, volts and amps (depending on mode) remotely if you are so set up.
I assure you, just having wire speed on my spoolgun has saved many laps back over to the welder...
Adding volts adj too will be trivial.
FWIW, I burned some stick the other day with my SW just to test it out after getting power to it,
...Used the TIG torch as a clamp I didn't have a clamp for stick or a place to hook up..
For giggles I used HF start on stick. Worked GREAT, fired right off and laid decent beads on nasty rusty scrap.
It should be possible to do a lift start on the 181i so you aren't running around with a hot stick if you add a finger switch.
(the welder doesn't know/care if it's not a TIG torch)
1999 Synchrowave 250, Bernard cooler.
TA 181i, US version, with TA 181i Euro connector, Euro on torch.
Firepower spool gun w/Euro connector, modded to suit 181i
Pressure controlled TIG amptrols.
TD PacMaster 100XL plasma cutter
