Results 1 to 14 of 14
Thread: CNC Plasma Project
    Apr 2016
    Tasmania, Australia
    CNC Plasma Project
    Hi everyone! I'm new to this forum. I'm a welder by trade and have been in the industry for 5 years (1st year tradesman). I work on a mining site in Tasmania Australia. Just thought I'd share some pictures of my CNC machine that I have constructed in my spare time over the past year. Let us know what you think!
    -Geckodrive G540
    -CandCNC LCTHC
    -Thermal Dynamics Cutmaster A120
    -Mach3 & Sheetcam
    Travel dimensions are roughly 1400mm x 3000mm.
    1605 ballscrew torch height control & rack/pinion long travel.
    Nema 23 stepper motors
    Magnetic breakaway torch mount
    Water bed with drain/fill pumps plumbed to external 1000l tank
Size:  67.5 KBName:  20160413_145051.jpg
Size:  51.5 KBName:  20160413_145417.jpg
Size:  45.5 KBName:  20160415_232048.jpg
Size:  42.0 KBName:  20160417_195244.jpg
    Apr 2016
    Tasmania, Australia
    Re: CNC Plasma Project
Size:  59.3 KBName:  20160421_141118.jpg
Size:  64.1 KBName:  20160421_141134.jpg
Size:  42.9 KBName:  20160424_214554.jpg
Size:  46.0 KBName:  20160424_214642.jpg
    Jan 2016
    Michgan
    First welcome to the forum. Just something I noticed was that you slides on X axis are unprotected from the dust and sparks from plasma cutting. Do you think that will be a problem for the long term?
    Klutch 220si mig , stick, and dc tig
    Hobart 140
    AHP ALPHA 200X 2016
    Lotos LTP5000D
    Smith O/P
    Jan 2011
    She's a beauty, nice work!
    Mastering others is strength, mastering yourself is true power.
    Feb 2015
    Atlanta-ish
    Fantastic work. Did you make the doors?
    -Chris
    Pensacola , Fla
    very nice looking table your going to have fun now.
    The only thing I would do is mount you slats so you have a curve is them maybe off set the center by putting the center in the next groove over right or left. Straight one seem to wobble when the torch changes directions.
    Hypertherm 65
    Everlast PowerTig 255 EXT
    Miler 180 Mig
    13" metal lathe
    Mill/ Drill
    ECT, ECT,
    Jun 2014
    SE Oklahoma
    Welcome and she's a beauty!!!!
    Located In SE Oklahoma
    Lincoln Mig 135
    Hobart Ironman 230 Mig
    5x10 CNC Table with DTHC & FT
    Hypertherm PM65 on the table
    Miller Bobcat
    www.caneyagequipment.com
    Apr 2016
    Tasmania, Australia
    Quote Originally Posted by tinker001 View Post
    Thanks. Yeah i'll keep an eye on it once I get the unit running & may have to develop a cover then!
    Apr 2016
    Tasmania, Australia
    Thanks mate
    Quote Originally Posted by blueriver View Post
    Apr 2016
    Tasmania, Australia
    Thanks for the heads up. I can flip the center slat locating bars which will offset them. May have to give that a go
    Apr 2016
    Tasmania, Australia
    Quote Originally Posted by Mr. Smith View Post
    Yeah built the lot pretty much
    Apr 2016
    Tasmania, Australia
    Quote Originally Posted by Mick120 View Post
    Good job Cody.
    I'm with acourtjester, get those slats curved across the table, it also prevents following if you're cutting straight lines.
    I'd also be inclined to close them up a bit, maybe 50mm spacing.
    I'll do that, makes sense. How will I benefit by closing the gap?
    Apr 2016
    Tasmania, Australia
    Preventing tip ups.
    I guess it depends on what size designs you're going to be cutting.
    I actually have the option of 25mm spacing for the smaller stuff.
    Thanks for the advice! I may have to modify the slat setup at some point. Appreciate all the helpful tips.
    Apr 2016
    Tasmania, Australia
    I originally got plans so worked off that too start off with. But the engineer who drew the table hadn't taken into consideration a lot of things. E.g longtravel with a 1605 ballscrew over three metres long......slats above water level by 100+ mm therefor defeating the fume collection aspect. Not 100% sure yet, probably more decorative kind of stuff. Gates, signs, fence panels etc.
Page generated in 1,664,381,910.64518 seconds with 12 queries
