Results 1 to 6 of 6
Thread: Blowing smoke and shooting oil perkins
    Jun 2015
    99' sa250 just put a new head gasket on and 2 new injectors and resealed the motor. Has 3500 hours on her and yesterday after running it for 11 hrs straight towards the end it started puffing white smoke. From low to high idle it would be a puff of smoke. When it's high idling it's a sheen of white smoke. None to little on low idle. Also happend to start blowing a little (what I presume to be oil) out of the exhaust.
    I'm hoping it's just another injector issue , too much fuel or whatever.
    I need some guidence. Will it hurt the motor to keep running it like this? Obviously checking oil consistently to make sure she doesn't run dry
    Kentucky
    Re: Blowing smoke and shooting oil perkins
    If it's water cooled check the water white smoke on diesel can be from water leaking into cylinder or a number of other things
    If it's not puking water out of the radiator overflow I doubt it's a head gasket issue and in light of the wet stacking I'd suspect an injector problem.
    You can isolate it to the affected cylinder by cracking each injector line nut one at a time with the unit running on high idle to see which one makes the white smoke go away.
    Save Second Base!
    Forgot to say, if it's an injector problem dumping too much fuel you definitely don't want to keep running it as the excessive fuel will wash down the cylinder(s) and you run the risk of seizing or at least scrubbing a piston.
    Whatever the case, it's not right and you need to find out the cause and not keep running it.
    Save Second Base!
    May 2009
    I have an 04 300d that did the same thing but it was the head gasket. I had the head pressure checked and had valves reseated. The head was still within spec .002. Put it back together last week and filled fluids. Went to check oil before start up one last time and noticed I was above normal. Coolant got back to my oil pan somehow. Pulled the head back off yesterday and came to the conclusion that the head may have been in a bind on the dowel pin somehow when I assembled. .
    Jun 2015
    Quote Originally Posted by dg09us View Post
    Hasn't done it since that day, I've ran it pretty hard since then. It was most likely an injector messing up. Zero water in my oil or blow by
Page generated in 1,632,739,643.07179 seconds with 13 queries
