Results 1 to 10 of 10
Thread: First Time Stick Welding, Stainless Steel Rods, Old Jackson Helmet
    May 2016
    I couldn't start a bead on Ac, the rod stu
    ck to the steel. Switched to DC got some beads to start.
    All I have are some old stainless steel rods, Airco 19-9 the label is torn, haven't been able to find out anything about them.
    The hardest thing for me is starting the bead, I guess I'll get the hang of it with practice. Can't see anything either. It's OK just practicing, but how did welders start a bead before auto darkening helmets? Sure need to get one. What should I look for when buying auto darkening helmet, and what to avoid?
    Thanks for any help on starting a bead or weld, how to improve, good habits, what not to do.
    Dec 2015
    Western New York State, USA
    Re: First Time Stick Welding, Stainless Steel Rods, Old Jackson Helmet
    use correct amps for rod diameter. use big enough rod diameter for material thickness. weld start do spiral or circle and circle weave as long as needed (to avoid cold weld starts)
    many rods do better holding a arc length. for example 1/8 dia rod use 1/16 to 1/8 arc length
    Jan 2016
    northeast USA
    Get yourself some 6013 rod to practice with..you will be amazed how much better the beads will be starting out...and grind to shinny metal....
    May 2016
    Thanks Tom,
    I've been studying about amps, rods and rod size vs material thickness adjusting the machine accordingly. I've still got a lot to learn but loving it.
    May 2016
    I'll go get some 6013 today, the rods I have are old, they may have drawn moisture, thanks
    Nov 2012
    new york city
    hm; you probably know this already but if you stick with the stainless rods wear safety glasses or flip up hood because the flux will pop off and fly a good distance as it cools.
    i.u.o.e. # 15
    queens, ny and sunny fla
    May 2010
    Port Orchard, WA.
    Quote Originally Posted by docwelder View Post
    Boy thatís the truth! Back when I use to build a lot of food processing plants I ran a lot of stainless steel SMAW. The slag always seems to pop off and land on your face.
    Donít pay any attention to me
    Iím just a hobbyist!
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    Jan 2011
    Ive used stainless 308 to weld mild steel.That includes welding exhaust tubing.Used an old ac welder.It can be done.I had the stainless rod on hand so I used it.Get a small pack of 7014 rod for practice.
    Sep 2014
    Greensburg Pa
    Id save the stainless rods for stainless/cast iron jobs. Get urself some 7018 or 6011
    Dynasty 200DX (2014)
    Millermatic 211 (2015)
    Optrel 864 (2014)
    Smith Medium duty MBA 30510 (Xmas 2014)
    Tennsmith 16ga 4ft finger brake (2015)
    Trailblazer 325 EFI and excel
    Thermal dynamics Cutmaster 82
    Miller maxtron 450
    May 2016
    I wonder if that has anything to do with the heat? I noticed one of the rods got red, here it is after I noticed it and discarded it.Name:  20160521_165001.jpg
Page generated in 1,634,905,663.60965 seconds with 12 queries
