Page 11 of 11 FirstFirst ... 91011
Results 251 to 273 of 273
Thread: Garage modification
  1. #251
    San Jose, CA Kelseyville, CA
    Re: Garage modification
    Yes it does. Just not a 1700$ one that sold for about $4000.
    Totally agree with you, but one will come your way...be patient.
    Great shop upgrade you did here, I see now why you want a mill.
  2. #252
    Apr 2014
    MN/WI
    Here ya go : https://www.facebook.com/marketplace...64856584368321
    Bridgeport mill variable head
    $1,200
    Listed a day ago in Milaca, MN
    Lincoln Idealarc TIG-300
  3. #253
    Quote Originally Posted by bead-boy View Post
    $1,200
    The will probably sell pretty quickly being that it has the variable speed head on it.
  4. #254
    But anytime the seller tells you it's well used, it means it's well used...
    Not to mention it's a good 5-6 hour drive from you...trying to negotiate is always advantageous if possible. Sometimes just being honest with people and telling them you have only X amount of $$$s to work with can secure a deal. Just sayin'...
  5. #255
    Quote Originally Posted by TraditionalToolworks View Post
    Yeah the well used thing is definitely true. I have the mill- drill which does what I need for the most part. Eventually one will pop up at the right time.
  6. Likes TraditionalToolworks liked this post
  7. #256
    You will find something local, or close enough, and be at a price you can afford. There is more old iron on the market than ever. Keep the truck gassed up with the trailer waiting when you need it!
  8. #257
    I'm not dead set on a Bridgeport either. God forbid I would even consider an Asian clone🤣
  9. Likes TraditionalToolworks liked this post
  10. #258
Size:  68.5 KB Here's the rack for storage cases I built a while back. Hard to believe it's been 5 years now.
  11. #259
Size:  92.5 KB. Also installed a 5 hp rotary phase converter. I ran power directly from it to the lathe and also ran conduit up and over the ceiling to a 30 amp twist lock 3 phase receptacle.
  12. #260
    Sep 2005
    Cave Creek AZ
    We know what comes next
    It usually involves the fire department and an insurance adjuster.
  13. #261
    Sebeka and Bemidji MN
    I will be doing the same once this new place is set up and we've sold her house.
    My house was sold last year.
    Syncro 350
  14. #262
    I would mount the phase convert on the block wall to keep noise down. I would put the covert outside.
  15. #263
    I do not moving it is pain it takes years for everything to be right again. I can fell your pain.
    The first I do after my car is in garage I install a sub panel for power. It was also used for kitchen too.
  16. #264
    Not a good option as we get a fair amount of snow here. It's not very loud anyways.
  17. #265
    You put cover over the converter and put the aircompresser outside under the same cover.
  18. #266
    And how would that work when it gets 10 -30 below zero in my climate? If it would have been practical I would have done it when I put the stuff in.
  19. #267
    I would build enclosed in summer.
    If live in Alaska they build below 0
  20. #268
    I've got a bud who does paint and body. Runs two 80 gallon compressors to keep up his air supply.
    He got tired of listening to them and put them outside the back wall under a cover - but didn't enclose them.
    Must not hurt them much, still running last I saw...I've considered it myself...
    Coldest it ever got in my old shop was about 0 deg f.
    My compressor still kicked over like it was in a warm shop - not sure what it would do at -30, too expensive to try it
    Syncro 350
  21. #269
    I always worried about lines freezing up. With so many cordless and corded tool options now I really don't use compressed air much. Mainly for a blowgun and airing up tires. It did get a good workout last year when I did the body and paint work on the last truck project.
  22. Likes whtbaron liked this post
  23. #270
    Mar 2005
    Under a Rock
    The lines probably wont freeze up but if you run an auto drain, that will surely freeze up.
    Also the amount of condensation youre putting in your tanks, they are probably rusting internally at a rapid pace.
    Even though its outside in the cold, The compressor is still pumping hot/warm air into a freezing cold tank.
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
  24. #271
    Yeah way too many negatives to a few positives. Oil is cold causing a huge load on the motor. Pressure switch can get finicky and even V belts don't perform well in the cold. In 40 or so years I've never been around an outside installed compressor so I don't see the need now. Certainly auto drains would fail in just about any freezing situation.
  25. #272
    My old air compressor sat in an unheated shop for years. My new one is in a heated dog house on the side of the shop and I'd never go back. Yes, lines do freeze up, moisture in the bottom of the tank is there until spring, belts get stiff, oil gets stiff and probably speeds up wear in the compressor itself, and you need the subzero hoses or they get so stiff they are a pain to work with. Doghouse is my solution. Coldest my old shop got was likely somewhere around -30C.
    Cut 50 Plasma
  26. Likes 12V71 liked this post
  27. #273
    When had my shop I used 60 gal tank so air compresser did not have cycle as often.
    They make oil for wide range temperatures.
    Where live it rare it drops below 32F.
    But we had wait till temperatures was above 65F for painting.
    The summer comes night temperatures are in upper 80'sF daytime 110'sF a different problem for oil.
Page generated in 1,632,148,738.36260 seconds with 13 queries
