Page 3 of 11 FirstFirst 12345 ... LastLast
Results 51 to 75 of 273
Thread: Garage modification
  1. #51
    Jan 2008
    Lansing, MI
    Re: Garage modification
    The former owner was a complete hack when it came down to hanging the drywall and doing the wiring. Most of the screws were sunk right thru the paper and pieces of drywall with no reasoning as to which direction it was put on. Most of the outlets weren't mounted very well either.
    I bet he thinks he's gods gift to home improvement tho
  2. #52
    Dec 2009
    Stevens Point, WI
    Don't forget to tie all of the bay door openings together as well, those are the weakest part. Your sure moving along fast!
  3. #53
    How's thisName:  IMG_20160530_124229148.jpg
  4. #54
  5. #55
    More bracing.Name:  IMG_20160530_124111361.jpg
  6. #56
    More of the same
  7. #57
    Another of the sameName:  IMG_20160530_124040764_HDR.jpg
  8. #58
    Just about ready to start lifting. Need to tie the 8" channel to the ledgers first.
  9. #59
    Sebeka and Bemidji MN
    Looks great - How many miles are you hauling it?
    Syncro 350
  10. #60
    I think it would hold up for moving, thankfully we don't need to do that
    Those t-25 headed construction screws sure are the ticket. I used 10 pounds of the 3-1/8" screws so far.
  11. #61
    COOL DAVE !!! I think Mike bought sooooooooooooooooooooooo much lumber he has to use it all up .
    More is always better . Nothing wrong with another 10 pounds of screws and 100' of additional lumber.
  12. #62
    Most of the lumber was junk or free. There are many treasures to be found in the vast expanses of the " Land of crap".
  13. #63
    Those screws are awesome
    Syncro 350
  14. #64
    The best kill is overkill
    Syncro 350
  15. #65
    You are absolutely right. Being a UNION Pipefitter / welder for over 40 years , EVERYTHING is overbuilt. One over my owners had us build a spreader bar because he didn't trust some factory manufactured one. Nowadays, they need to be stamped , approved, and weight limit on them.
    The old man owner got a new water heater for free because the legs were broke. Brought it to the job sticking out of the trunk of the Lincoln and said make me a base. I was doing a pipe job with 20'' pipe, so he had a base with 20'' pipe to set it in. Talk about overkill, not to mention the base cost more than if he would have bought a new heater.
  16. #66
    The thing with overkill is you never see the limit of something, unlike having something that isn't strong enough.
  17. #67
    Mar 2016
    Minneapolis MN
    you might want to think about core filling the block with some rebar in there too, especially around the doors and back corners....couldn't hurt!
  18. #68
    Quote Originally Posted by cloudman View Post
    You must have read right passed it. He mentioned that on post #29 or so.
  19. #69
    More bracing with the steel. Not much welding, just some short welds with damp 7018Name:  IMG_20160530_171956405_HDR.jpg
  20. #70
    More of the sameName:  IMG_20160530_172011399.jpg
  21. #71
    We have liftoff.Name:  IMG_20160530_184606388.jpg
  22. #72
    Not too bad for creaking and cracking. I used 20 ton jacks, but 8 ton would have been plenty. My next step is to disconnect the wiring coming in and cut the conduit.
  23. #73
    Nov 2010
    Mid-East
    Damp 7018? You know that will never hold!
    Looking great.
  24. #74
    Dec 2009
    Stevens Point, WI
    That is almost enough lumber to rebuild the walls to 12'!
  25. #75
    Quote Originally Posted by tbone550 View Post
    Looking great.
    I hear you about the 7018 not being in an oven. No current certifications either.
Page generated in 1,624,073,318.13574 seconds with 12 queries
