Results 1 to 21 of 21
Thread: Ugly Drum Smoker
    May 2011
    Alabama
    Ugly Drum Smoker
    Here is a smoker that I made out of a 55 gallon food-grade drum. Initially, I tried to bend a cheap Uniflame lid to fit. I scrapped this idea and ordered a Weber lid. I installed a Rutland stove gasket on the lid and it is air tight. This thing smokes great. It will hold temps from 225-325F. I can get about 10 hours out of 1 basket of charcoal. Also, there are some pics of things that I have smoked. The first is a boston butt and the second is a chuck roast.
    May 2008
    Orange, TX
    Re: Ugly Drum Smoker
    Any smoker that turns out a fine looking piece of meat like that sure ain't ugly!!
    I just finished supper and now I'm hungry again. Nice job!
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Feb 2008
    Discovery Bay, CA
    I'll take a pulled pork Sammy stat!! Nice looking UDS!
    Jan 2006
    I have envied them for years over at the smoke ring forum. I am going to build one for sure this year. I do have one question. what is the pipe and nipple on the side for? I understand the valve is for the air, but what about the other?
    Great build by the way.
    May 2011
    Alabama
    Quote Originally Posted by Scott Young View Post
    Good question. I welded in three 3/4" black pipe nipples for air vents. 2 of them are capped and 1 has a ball valve. When bringing the smoker up to temperature, I have all 3 wide open. When I get within 25* of my target temp, I put the caps on 2 of them. Smoking at 250*, I have 2 valves closed and the ball valve about 3/4 open. Also, when cooking wings, I smoke them at 250* for a few hours. Then, I open all 3 vents wide open and bring the smoker up to 350-400* to crisp up the skin.
    red rock country
    Was the inside of that barrell coated, or plain steel? I've got a bvarrell sitting in my backyard, and want to make a smoker, but the inside is coated and I'm not sure of the best way to get it out. Also, do you load the charcoal in from the top, or is there a door on the other side?
    Apr 2008
    Yuma AZ
    Birdwell, burn it out, nice & hot. Put your air vent holes in first, then let that puppy burn.
    I used a cut up pallet on mine. It was a former grease drum.
    Fill the charcoal basket from the top, then the grate goes on. Meat or ABT's goes on the grate. 6-10 hours later, pull off the meat & let it rest for a while.
    You won't be sorry if you build one.
    Mark
    Craftsman 12"x36" Lathe
    Enco G-30B Mill
    Hobart Handler 175
    Lincoln WeldandPower 225 AC/DC G-7 CV/CC
    Add a Foot Pedal to a Harbor Freight Chicago Electric 165A DC TIG
    PapaLion's Gate Build
    Jan 2006
    Quote Originally Posted by morgaj1 View Post
    gotcha...That is what I figured but having never read about it, and only seeing it, I was at a loss.
    Jul 2011
    I'll be making one of these http://www.thesmokering.com/forum/viewtopic.php?t=32327 this winter/spring. and can't wait! I'm salivating already.
    There are no problems. There are only solutions. It's your duty to determine the right one.
    Hobart Handler 210
    Airco 225 Amp MSM Stinger
    May 2011
    Alabama
    Quote Originally Posted by Birdwell4 View Post
    I have a basket I made out of expanded metal on the inside.
    It's ugly, but works real well. I couldn't get the expanded metal to form a nice circle, but it still works. If I am going to be smoking for 8-10 hours, I will put about 7-8lbs of Kingsford blue bag charcoal in the basket. Then, I start about 15 coals in the chimney starter. Once they are white hot, I pour them over the unlit coals (minion method). I also add about 3-4 chunks of hickory, cherry or apple wood. As long as you don't keep lifting the lid, these things are rock solid in holding temps. Since I got the drum for free, I've got maybe $100 in it. Best $100 I've spent in a while.
    May 2010
    L.I. NY
    Wow what time do we eat!!!!! ugly doesn't matter the meat can't see anymore, heck I'm ugly and I work real well!!!
    Sep 2011
    the meat looks so good i almost forgot the thread was about the smoker
    Miller 211 w/MVP
    Spoolmate 100
    Turbo-Torch
    and the ever popular B.F.H.
    I built one a year or two ago and love it. Last smoke I got 19 hours at rock solid 225 degrees, never had to touch it. I need to add a shelf and wheels for mine, just haven't gotten around to it.
    Charcoal basket:
    Inside:
    UDS:
    It's painted now. Those pics were when I first built it. It has made some good eats.
    Slicing up a fatty:
    1st Butt:
    Yummy...
    Nevermind, got my pics resized.
    Jul 2005
    Escondido CA.
    Built mine about 3 years ago and still going strong. I have built at least 10 this past summer for co-workers and in the finishing stages of another this weekend. last picture is a San Diego Chargers smoker
    Dec 2005
    I built one a couple years ago as well, and I love it! People can't believe the food that comes out of it! I want to add some wheels, and a shelf on the outside of mine, but haven't gotten around to it.
    I added a pizza pan from wally world on the bottom of my basket to act as an ash catcher. When I lift out the basket, the ash comes with it, no need to dump the barrel.
    Can easily fit 3 8-10 lb pork shoulders on the bottom rack, and 3 racks of ribs on the top....mmmmm
    May 2011
    Alabama
    Wow, y'all's smokers look much better than min. I like the liftable basket idea. It is a pain to shop-vac mine out every time.
    Nov 2010
    This will be my next smoker project, I'm holding out for a food grade barrel.
    May 2011
    Alabama
    Quote Originally Posted by SeanMurphy265 View Post
    Try to find one without a liner. A good idea is to see if there are any food processing plants in your area. Most of their hydraulic equipment must use food-grade hydraulic oil. I got mine from a chicken processing plant that had food-grade hydraulic oil in it and no liner. It was a breeze to make. I cut the top out with my plasma cutter and then burned it out. It came out nicely.
    SE Wisconsin
    I made one about a year ago, got some tasty meat from it so far.
    Jim
    Jan 2008
    Kansas City (Excelsior Springs)
    Here is a picture of mine, love this thing. I smoked a 14hour brisket and slept through the night. un believable how efficient they are.
Page generated in 1,713,273,475.13403 seconds with 19 queries
