I just acquired a simple oxyfuel setup with a 40cf B size acetylene tank and a 80cf Oxygen tank for portable use. I was a bit surprised in reading the Victor literature for a Victor medium torch to find that if I adhere to the 1/7 or 1/10 rule on consumption of acetylene rate that virtually all cutting and heating operations are "illegal" and that the largest welding tip that can be supported by the B tank is either a 0 or 1. A number 4 rosebud far exceeds the cfh limit and according to the Victor charts so does even a 000 cutting tip! I was rather stunned so I called Victor technical support and they confirmed that their specifications and limitations are correct. Essentially the B tank is limited to 0 or 1 tip welding or brazing/soldering operations.
I have a hard time imagining that in the real world people are not using B tanks more aggressively (and presumably safely) for cutting and for welding at least 1/8 steel (#2 tip). Victor even packages a cutting tip and 0 tip with their little 10cf portatorch set up both of which are way too big for the acetylene tank in those carrykits. I'm confused. What is considered reasonable use of a 40cf B tank by those of you with experience with portable oxyfuel set ups?
