Results 1 to 16 of 16
Thread: gas shielded flux core wire welds
    NW New Jersey
    Wanted to use some gas shielded wire for welding an I-beam out of position. Did some practice welds with .035" E71t-1 dcep at 23 volts 300 ipm on a Lincoln 210mp. The welds look really weird to me. Almost like bubble gum. Never had a weld come out like this before. Is this what they are supposed to look like. I've used outershield 212 before and that looks like a normal weld. Will try to post pic's later.
    Jun 2015
    Alaska born, Alaska bred
    Re: gas shielded flux core wire welds
    Can't say that I've ever heard of a weld looking like bubblegum...
    That being said, a properly executed dual shield weld will look different from 7018 or self shielded wire.
    Apr 2010
    You do have to have a high flow rate on the shield gas 40 - 50 cfh i run 75/25 Argon / CO2 mix and stickout is critical at 3/4 to 1 inch
    I mostly run outershield 71-M in .045 and .062 ,,,These wires are susceptible to moisture so if it get exposed to water or high humidity it will cause that also
    When it is done just right it looks like chrome after cleaning off the slag
    Pics would help
    What would SATAN do ??
    Miller Trailblazer 302 AirPak
    Miller Digital Elite
    Optrel Welding Hat
    Arcair K4000
    Suitcase 12RC / 12 VS
    Hypertherm PM-45
    Rage 3 saw
    Rusty old Truck
    NW New Jersey
    Sorry, must correct that, I've welded with Innershield NR-211 E71T-11, and NR-212 E71TG-G . The wire I'm welding with now is similar to the Outershield 71-M, only its new box of blue demon wire. I'm only using 30cfh of 75/25 Ar/CO2. It just doesn't have any ripples. The slag comes off really easy, like 7014 very shiny underneath. Will post pic's later.
    Jun 2015
    Dual shield welds should be shiny, with easily removable slag, and a flat surface. No ripples.
    NW New Jersey
Size:  50.6 KBName:  0609161944.jpg
    3 passes vertical up, slag almost came off by itself. The older weld in the background was done with InnerShield NR212. At first I didn't realize that it was DCEP, the blue demon box doesn't say polarity, or amps. I just ran it like InnerShield, those welds were really awful. Was thinking of using this wire to weld two pieces of
    6.5"x 8" H beam together. Its for a 25 year old logsplitter beam. I just cut off the welded on wedge, and ground all the welds off of it. Soon I'll be cutting the twisted section of H beam of and welding a repair section on. I built it 25+ years ago from scraps in a injection molding plant, the beam was two left-over pieces that I welded together. The beam cracked about 12 years ago, and I re-welded with some 7010 rod. It's probably split over 500 cords of wood. It's time for an overhaul. So many knotty 36"dia. oak logs. Its amazing how much twist you can get on a beam with 20 ton. Original welds were done with an EconoTwin HF with 1/8" 6010 first pass, 1/8" 7018 two cover passes.
Size:  62.1 KBName:  0606161948.jpg
Size:  79.1 KBName:  0606161949b.jpg
    Jun 2015
    That's close to what they should look like. It looks like you're running a little cold. I don't know what diameter wire you're using, but for .045", it should be run 350-450IPM and 26-29 volts.
    NW New Jersey
    Thanks HW, I was running 23v at 300 ipm .035 wire. Tried lower first and didn't look good using settings for Innershield. When I brought them up I got this. Max volts on this machine is 25v and max wire speed is 500 ipm. Hopefully I'll have enough snot to get this to flatten out and wash smooth to the edges. I'm thinking the spool of .045" Outershield isn't going to work on this machine. Appreciate the feedback, its a new machine and a new wire, and I was exactly sure what it was supposed to look like, and what might be wrong.
    Aug 2011
    Cape Cod, MA
    Set the volts to 25 and dial in the wire speed, probably around 350 - 400ipm. I have that machine and the Outershield 71M .035 works nicely in it. You will not get .045 Outershield to run in the 210MP but .045 NR-212 runs great.
    If you ever get a larger MIG, get some .045 Ultracore 71A85 and you will see just how nice gas-shielded flux-core can be!
    John
    A few welders
    A lot of hammers
    A whole lot of C-clamps
    NW New Jersey
    Thanks for the settings/info. Its the opposite when I run aluminum without the spoolgun, I set the wire speed at 500 ipm(max) and find the voltage. Will try running the 71m again today. I have been burning some NR-212 .045 and just cant get the a couple of stringers without getting a little porosity. I've changed settings, stickout , angles etc. Doing the same thing over and over, and expecting a different result. Some call it insanity, I call it practice. Kinda making me crazy, I want to use this to put the logsplitter back together again. I'll be looking at it all the time so I want it to be right. The NR 212 has some real punch to it almost a 6010/6011 dig to it. The 71M just looks odd to me, I wasn't going to use the solid wire to save on cleaning work, and the flux core seem to have better penetration. I don't know if the wire runinspeed might help on the rough starts. Gotta get this done, winter is coming.Name:  0613162309.jpg
Size:  48.6 KBName:  0613162310.jpg
Size:  62.4 KBName:  0614160615.jpg
    Jun 2015
    That's the nature of aluminum. You need lots of wire to carry lots of heat because aluminum is a great heat sink. It's also very easy to burn it back and ruin the tip, that's why you have to be careful with the voltage.
    So you've switched from FCAW-G to FCAW-S in these latest pictures? What are your settings for it?
    NW New Jersey
    140 Ipm 19v , 160Ipm 20v, No gas, 1/2" steel plate . I tried again today, and I adjusted "wire run in" to 75 to make a better start, but still i get an occasional pocket or hole. Even changed the inductance lower, doesn't seem to dig as hard, but still some voids. Thinking about running .035 solid wire 75/25 COAr. or maybe 71M if I can get a good bead... I'll try new settings on 71M Winters coming.
    NW New Jersey
Size:  50.3 KBName:  0615161708a.jpg
Size:  43.0 KBName:  0615161708b.jpg
Size:  52.0 KBName:  0616161237.jpg
    71M Outershield 24 v 320 ipm .035 co2ar 35 cfh Looks like I'm going with the outershield. Innershield specs at 3/4" plate max , Logsplitter wedge is 1-1/4" in. thick so 71M is a better choice anyway. I think its stick out that keeps getting me, I kept reverting to solid wire distance, on the Innershield (NR-212).045
    Jun 2015
    Max plate thicknesses need to be taken with a grain of salt, because you aren't welding just one pass. The beads you deposit on a piece of 3/4" steel are going to be every bit as strong in a piece of 1-1/4" steel. Pretty much all processes except MIG generate enough heat that pre-heating isn't typically an issue. That said, dual shield will still serve you well.
    NW New Jersey
Size:  48.4 KBName:  0606161201a.jpg
Size:  47.0 KBName:  0609161751.jpg
    Original was pre heated no bevel 6010 new box 7018 and I got a little cracking in the front of the wedge to H-beam area. Couldn't hurt to use the Dual shield to make up for my welding flaws. Lincoln has a HUGE warning on the NR-211 not to weld anything over 5/16", but only a small notice on the NR-212 not to weld anything larger than 1/2"(thats about a grain of salt) . If all I had was NR-212 in .045 I would use it. My original plan when I bought the lincoln 210mp was to run solid wire mostly, but I'm finding that a lot of the flux cored wires really work well in a lot of places(and I don't have to drag a bottle to the top of a silo,or catwalk). I've done lots of Tig, and stick repair welding over the years, but only limited Mig work. Just now getting the hang of new machine, new process. I've welded all the scrap in the pile out back together practicing. My boss wants to know if its an art project, or an anchor. Probably used up 7 lbs of NR212 this week. Hope to start welding splitter together this week. Then again maybe I should buy my fishing license. Winters still a long way off isn't it ?
    NW New Jersey
    Name:  0716160605a - Copy.jpg
Size:  53.4 KBName:  0716160604a - Copy.jpg
Size:  57.1 KBName:  0701162034 - Copy.jpg
Size:  40.6 KBName:  0716160603 - Copy.jpg
Size:  56.9 KBName:  0716160604 - Copy.jpg
Size:  62.4 KB finished welding H-beam back together. Made clevis from left over dump pin pivot, 1" plate with 1-1/2" hole. Cut with O/A torch. Just as I finished, the oxygen regulator blew out, hisssing like crazy. Finished cutting with grinder. Welded wedge back on first pass was .035" fabshield 21b with some bevel, followed by two passes Blue Demon e71t-1 Ar/CO. Love the way that slag curls right of the weld. Hopefully it all hold together, the splitting pile has been buliding for 3 months now. It's gonna be 90 deg again today , but winter will be here before you know it.
Page generated in 1,664,049,113.62050 seconds with 12 queries
