Results 1 to 6 of 6
Thread: Aluminum dump body Welding
    MA
    Im spool gun welding some new plate in the bottom of an aluminum dump body, never welded aluminum before but it is going nicely.
    I am wondering about protecting myself from reflections from behind me, I am wearing a bib around my neck to stop reflections that way - should I be doing anything else? I got half way done today and my eyes are ok a little dry from the smoke but other than that fine. I am a mechanic that welds occasionally that's why I am asking.
    Soldotna Alaska
    Re: Aluminum dump body Welding
    If your in a shiny box welding cover all skin and use sun glasses that are uv rated and use sunburn lotion otherwise you will peel for a month .
    trailblazer 302
    thunderbolt ac dc machine
    Hobart fluxcore
    AHP tig 200x 2015
    SoCal-LA
    Quote Originally Posted by akphill View Post
    The sunscreen is a good idea akphill. For the eyes I use wraparound amber safety glasses.
    b.c. canada
    I just use a old hoodie and then put my half leather jacket overtop
    High Octane Welding
    Aug 2009
    western new york
    When I have to crawl inside a pipe to weld something, I use a piece of an old weld jacket taped to the back of the hood. It keeps all reflection off my neck and out of my eyes.
    IAMAW Local 330
    Airco 300 AC/DC Heliwelder
    Airco Dip-Pak 200 with Profax spool gun
    Powr-Kraft AC225
    Everlast PowerArc 200st
    Buffalo Forge No.21 drill press
    Speedglas 9100xx
    Airco, Oxweld, Purox, Victor torches
    Lincoln Ranger 8
    Aug 2008
    Sudbury, Ontario
    Put a towel under the band of your faceshield, let it go over your head and down over your neck to your shoulders. Sort of like the arabs do with their head garb. If it's hot wet it down and it will keep you cool as the moisture evaporates.
    SA 200
    Idealarc TM 300 300
    MM 200
    MM 251
    30a Spoolgun
    Precision Tig 375
    Invertec V350 Pro
    SC-32 CS 12 Wire Feeder
    Oxweld/Purox O/A
    ArcAir
    Hypertherm Powermax 85
    LN25
Page generated in 1,627,858,949.55035 seconds with 11 queries
