OK, I have to humble myself, and say we were both right. I didn't think you could get cheaper, but the last one I ordered, instead of fixing mine, was much cheaper and smaller. It would not bend sch 40 2" pipe well at all. The heavier one was harbor freight "central hydraulics", The lighter new one was $100 with free shipping and had "CE" on it. So when I told you guys the 12 ton pipe bender was OK when used as intended, apparently that is not always the case. Unfortunately they all look the same on eBay, and I have no idea if the "central hydraulic" brand is as heavy as it was when I first bought one 20 years ago.
As far as rebuilding it, all the local shops don't carry the main pressure seal. I may custom build a one way cylinder or look around online for the jack seal.
In the pictures, the red die is from the older 12 ton pipe bender, the black one is the $100 one from eBay with unacceptable results.
