Results 1 to 18 of 18
Thread: 1952 General Electric Model 6WD4200 200A Wisconson VE4 powered welder info please
    Jun 2016
    I have had this welder for about 25 years and the only other one that I knew of was lost in a shop fire decades ago. If someone has used one I would like to hear about your experiences, or if someone has info on the welding generator aspect I would be interested. I have good information on the Wisconson VE4 if anyone needs.
    GE Model 6WD4200AG1 - Serial 48 TJ
    Jun 2016
    Re: 1952 General Electric Model 6WD4200 200A Wisconson VE4 powered welder info please
    There is a short video of the unit here if you are interested in what it looks/sounds like:
    May 2010
    laguna niguel, Ca USA
    Thats things pretty neat
    Miller Xmt 350
    Lincoln Ln-25
    Ahp 200x
    Smith Gas Mixer AR/H
    Tig is my Kung Fu
    Throwing down dimes and weaving about
    Instagram http://instagram.com/weldor_wes
    WeldorWes@WcWeldingLLC.com
    Soda springs,Id
    Those Wisconsin's are awesome engines for their power and durability. My old Hobart has the Wisconsin TJD 2 cyl. Don't know how many hours are on it, but I had the head off and the crosshatch is still visible. Mine is also a 200 amp machine but w/ direct drive. I see yours appears to have an overdrive thru the v-belts which I guess explains why it needs the v-4. My TJD only runs at 2300 RPM at welding speed. What RPM does your's run at?
    Mike
    Ol' Stonebreaker
    Hobart G-213 portable
    Miller 175 mig
    Victor O/A setup
    Makita chop saw
    Jun 2016
    Mike
    You are exactly right... The VE4 turns @ 1,800 rpm I believe and the welding generator part turns @ 3,500 rpm... Almost double. I wonder how much difference that makes on the DC cycle/weld quality?
    Soda springs,Id
    It probably is the torque peak of the engine and it uses less gas and lasts a lot longer than the new ones turning at 3600 RPM. I don't know about the weld quality but I'm sure the designers figured that in. My old Hobart at 2300 RPM welds sweet.
    Mike
    Ol' Stonebreaker
    Miller 175 mig
    Victor O/A setup
    Makita chop saw
    Jun 2016
    Yea, decades ago on the service rigs they changed from the old 1,800 rpm 10kw diesel Onan generators to plug in the block heaters in the winter overnight to some screaming Japanese 3,600 rpm things. I can well imagine what a modern 3,600 rpm welder would sound like after a days work. The 1953 Lincoln SAE 300 with a flathead six Hercules engine that I am working on will turn @ 1,500. Can't wait to hear it bark.
    Southern Illinois
    Nothing sounds better than a smooth 6 cyl under load with a straight exhaust. My SA200 with the flat head four is close
    Steve
    Lincoln SA200 (1966 Redface)
    Lincoln IdealArc 250
    Steve
    1990 Miller Dialarc 250
    1993 Miller Maxstar 140 STR
    2015 Lincoln MP210
    1966 Lincoln SA200 Redface
    May 2007
    i used to have a ge welder that look just like the one in the video. i don't remeber it being a 200 thouigh, i thought it was like 180 or so. it was set up w/ a wisc. 4 cyl. i alweays thought the welder was intended for a elect motor in a shop, not a wisc. i bought it not running and never got it running. i torched off the pulley off the wisc crank, before i sent it to scrap, i think i still got it laying around
    Jun 2016
    Yea, I am starting to think that this G. E. Model 6WD4200 is very rare... By now, most would have been recycled into foreign cars... I don't suppose that G. E. would have had much of a market share to start with when competing with the Lincolns and other good welders of the day. Thanks for your reply.
    If you have a picture of the one you had, and are able to post it, I thank you in advance.
    May 2007
    i wouldnt have the welder anymore, i pretty sure i have the pulley off the wisc, and don't recall torching the pulley off the ge welder, but i might of. i remeber my pulley off the wisc, having 3or 4 steps, not two like the one in the video
    Jan 2016
    Manitoba , Canada
    Hey Rod , that old wisconcon sounds pretty good , I can't wait to hear the 300 fire up .
    1963 SA200
    MILLER SYNCROWAVE 180
    THERMAL ARC 180
    HYPERTHERM POWERMAX 800
    DECKEL FP 3 MILLING MACHINE
    ZUBAL 14-40 LATHE
    BEER FRIDGE
    Hobby kinda got away on me
    Jun 2016
    Quote Originally Posted by DLHCC View Post
    Hey Rod , that old wisconson sounds pretty good , I can't wait to hear the 300 fire up .
    1953 Lincoln SAE 300: It's closer than you think! Starter and carb gone through and remounted. Side of engine painted while everything off. Valves set. Plugs cleaned. Timing marks found. Operator and service manual located. Parts manual purchased.
    Tank still needs cleaning, mag checked and mounted. Oil yet to be changed (with a cookie sheet) I guess.
    I will need your advice on straightening a couple of large items.
    May 2007
    i found both pulleys from that today. so if you need demensions or something from them, i can do
    Jun 2016
    i found both pulleys from that today. so if you need dimensions or something from them, i can do
    I am good for now, but, hey, thanks for getting back to me.
    Jun 2016
    Yea, I got the 1953 Lincoln SAE 300 running and welding well by late July 2016. I have more parts to make for it and will finish some cosmetic/paint stuff, but hey, I think it is going to be ok. The old Hercules QXLD-3 sounds sweet rolling along @ 1,500 rpm. It has the full two rheostat controls instead of 'gears' so I will have to spend some play time to figure it out. So, yea, this post is off topic...
    May 2009
    Lancaster, Ohio
    Have one of those engines sitting in a barn.
    Nov 2016
    Thats cool, I have the same one in the Barn, do you have any info on the starter on it?? Or numbers?? I always hand crank to start it.
Page generated in 1,632,704,931.32773 seconds with 11 queries
