Results 1 to 12 of 12
Thread: Problem with imports-in general
    Los Angeles
    A local farmer's market that I help with bought a generator from this company (before I came on board)
    http://www.extrememax.com/default.asp
    They asked me to take a look at it as it wouldn't start. Cleaned carb new fuel, runs.......but Prime Bulb is cracked.
    Ring Ring....
    "I need a remplacement prime bulb.."
    " We no longer offer that model, parts not available"
    sheite!!
    gotta see if I can find generic one that will work. No luck at box stores.
    MM211 (Sold)
    Klutch 120v Plasma cutter
    Apr 2014
    richmond, va
    Re: Problem with imports-in general
    Ed,
    Find out what brand of carb is used, if the bulb is on the carb. If the bulb is a remote, look at small chainsaws (1 of mine is remote). Good luck
    Regards
    Soda springs,Id
    The EPA is the only reason primer bulbs exist. There were a few idiots among us that didn't know how to properly use a manual choke, so EPA decided we're all idiots!! Now we have idiots that don't know how to use a primer bulb!! While I'm on the primer bulbs, on it's 3rd winter last year I decided to find out why snowblower engine was such a hard starter since new even w/ electric start. The primer bulb for it is remote and when I removed the tin it is attached to the little rubber hose to the carb was in pieces and had to have been that way the day I bought it new.
    Mike
    Ol' Stonebreaker
    Hobart G-213 portable
    Miller 175 mig
    Victor O/A setup
    Makita chop saw
    Jan 2016
    northeast USA
    Ring Ring....
    sheite!!
    ebay has lots of generic primer bulbs to fit many applications..
    Nov 2012
    Everytime that they make something more idiot-proof, they build a better idiot to compensate!
    OP take the bulb to a good size lawn mower/ lawn equipment shop and they can probably match it up. They did for me.
    CT
    Ed take the carb off, and scribble down any numbers you can find, and google search the numbers. chances are good there are still people selling that carb, even if it goes on a different engine.
    Miller Multimatic 255
    Dec 2008
    Scottsdale, AZ
    I had to mow my lawn once with a friends old mower and the primer bulb was compromised enough so it wouldn't start. I fixed it with a condom and a few loops of wire. Of course it didn't work to prime the carb but it was enough to fix the air leak and it ran fine. So, in a pinch...
    Jan 2016
    northeast USA
    Quote Originally Posted by pedaldude View Post
    just plug the primer tube with a screw and a shot of carb cleaner in the air filter will get you going..
    May 2008
    Orange, TX
    . . . aaand you your friend didn't have to worry about it getting his female lawn equipment pregnant!!
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Los Angeles
    Thanks guys.
    MM211 (Sold)
    Jan 2016
    northeast USA
    Southern Illinois
    Think of how disappointed the condom was!!
    Steve
    Lincoln SA200 (1966 Redface)
    Lincoln IdealArc 250
    Steve
    1990 Miller Dialarc 250
    1993 Miller Maxstar 140 STR
    2015 Lincoln MP210
    1966 Lincoln SA200 Redface
Page generated in 1,627,615,467.75590 seconds with 12 queries
