Is there any reason not to use stainless bolts on my thermostat housing which bolts into my cast aluminum water pump on my 7.3 Powerstroke?
I used Permatex 133K, which is now called #80078. They also added the word "Aluminum" on the front label. It says it is "a highly refined blend of aluminum, copper and graphite lubricants". I was careful to read the entire label and there was nothing saying not to use on aluminum. Are you thinking galvanic action?Don't use copper based anti-seize with aluminum. I actually find dielectric grease works best when putting stainless fasteners in aluminum. Dow Corning 111 costs much less and is the same stuff.
