Results 1 to 23 of 23
Thread: Electrical switch?
    Dec 2007
    Los Angeles
    Electrical switch?
    This is on the side of my friends house.
    I've never seen one and we don't know what it controls.
    house was built in 1945
    Ed Conley
    MM252
    MM211 (Sold)
    Passport Plus & Spool gun
    Klutch 120v Plasma cutter
    SO 2020 bender
    Beer in the fridge
    Jun 2015
    The wheat fields of Kansas,in a large metal building
    Re: Electrical switch?
    Where does it come from and, what is it connected to? Landscape lights? Pool or fountain?
    Steve from SoCal now in Hutch
    Miller Dynasty 300DX Coolmate3 Speedway Torch
    Miller XMT 450 MPa plus with D-74 MPa Plus
    Miller Bobcat 225 NT
    Hypertherm Powermax 45
    And a whole bunch of machines
    Jul 2011
    Bossier Parish La.
    That looks to be a cover intended for use in areas with a potentially explosive atmosphere. If you remove the cover, you will most likely find standard type light switches inside. At least standard for 1945.
    Western New York State, USA
    looks like water proof cover often a regular switch is inside it is just designed to keep liquids like rain out. fairly standard in factories with a lot of water being sprayed around to clean stuff
    wouldnt surprise me if found at tractor supply too. farmers hosing down the manure around the barn
    Dec 2007
    Los Angeles
    He does have a pool but the switches for the pool are inside the gare.
    maybe left over form the original pool equipment.
    Ed Conley
    MM252
    MM211 (Sold)
    SO 2020 bender
    Beer in the fridge
    Soda springs,Id
    Explosion proof, which in this age of lawyers would be called explosion "resistant". Saw many of them in the USAF in munitions storage/ handling areas.
    Mike
    Hobart G-213 portable
    I'd say the guys have it right.
    A newer Crouse-Hinds version . . .
Size:  42.6 KBName:  s-l1600b.jpg
Size:  41.0 KBName:  s-l1600c.jpg
    Save Second Base!
    Dec 2007
    Los Angeles
    Explosion proof for a residential house application??
    Ed Conley
    MM252
    MM211 (Sold)
    SO 2020 bender
    Beer in the fridge
    Jul 2011
    Bossier Parish La.
    Maybe they had easy access to them, and thought they would look cool for the purpose.
    explosion proof have o ring seals and gaskets which makes them water proof
    technically in high solvent areas i saw compressed air supplied dc motors. the fresh air over brush commutators that makes sparks was to force any solvent air that might leak in and instead fresh air would leak out
    explosion resistant or water resistant is what they are probably called now a days
    Oct 2011
    Elkhorn, WI
    1945?
    He should probe his yard for a "Bomb Shelter"!
    Probably some surplus that was available at the time and was originally on some yard lights or as suggested maybe a pool?
    Those are definitely not rated NEMA-7. No machined gasket/o-ring surface, material too thin and those 4 dinky little screws would likely not retain that cover in the event of an internal vapor/air explosion in that box.
    NEMA-4? Yes. NEMA-7? Definitely not.
    Save Second Base!
    Jun 2015
    If the house was built in 1945 then best guess is, who ever did that work bought surplus from war plant inventory. The brief may have asked for a water resistant switch, guy that did the work bought these cheap as surplus. Very likely 1946~51 era, Lockheed, North American, Douglas or, Northrop plus, hundreds of other heavy industrial plants. That was when L.A. was a huge center of war production.
    Soldotna Alaska
    I have different shape of switch but same thing
    I use them to control lights outside in the weather
    trailblazer 302
    thunderbolt ac dc machine
    Hobart fluxcore
    AHP tig 200x 2015
    Jan 2008
    Richmond, Virginia
    Look at the prices on those antique Crouse Hinds switches!
    http://shop.industrailia.com/Industr...itches_c24.htm
    $259. Name:  1298445106397-1532507713.jpeg
    Syncrowave 250 w/ Coolmate 3
    Dialarc 250, Idealarc 250
    SP-175 +
    Lincwelder AC180C (1952)
    Victor & Smith O/A torches
    Miller spot welder
    Dec 2007
    Los Angeles
    i saw those after I googled the name that Duane posted up :0
    Ed Conley
    MM252
    MM211 (Sold)
    SO 2020 bender
    Beer in the fridge
    Very cool!
    Willie
    Feb 2012
    I have a three gang. I thought it was/is just an old outdoor light sw cover. Explosion proof and $345
    Regular old light switches fit into the rockers. The switch part is all brass and cover is cast.
    Northern Cal., Shasta County
    Years ago they would use all switches (boxes) like that in coal mines. Phones, switches, everything electrical went into what was commonly called a 'mine box'. Now it wasn't because they wanted the protect the device from explosions, they wanted to prevent even the tiniest of arcs from causing an explosion. Coal dust and sparks were a bad mix. So they were explosion resistant in a different way.
    Jan 2008
    Richmond, Virginia
    Some interesting old electrical stuff for sale here: http://www.urbanremainschicago.com/p...vices.html?p=1
    SP-175 +
    Miller spot welder
    $259.
    I still question the claim of an explosion proof (NEMA-7) rating based on its construction and my experience in dealing with such rated enclosures. NEMA-5 at best is my guess with the more common 3 or 4 the better likelihood.
    http://www.nema.org/Products/Documen...sure-types.pdf
    Those single plunger pieces shown in the "vintage" link are actually mounted upside down and should be as the one in Ed's photo.
    Save Second Base!
    May 2015
    I think that drujinin may be correct about someone having used that cover because it was easily available as surplus. I think that my grandpa had the same type of cover (in a single-switch configuration) controlling one of the outdoor lights on his farm (he and the farm are both gone now, so I can't be absolutely certain, but it looks familiar). It wasn't used in a classified (hazardous) location, so it's likely that someone just used it because it was convenient.
    Dec 2011
    Tampa FL
Page generated in 1,627,394,428.41824 seconds with 14 queries
