Results 1 to 20 of 20
Thread: cutting 1-1/4" steel stock
    Jul 2016
    I have a Rigid 12" compound saw. I mainly cut wood but need to cut some 1-1/4" steel stock. I bought a 12" abrasive metal cut-off. Will this do the trick or will it ruin my saw or cause damage to me and/or saw? I need to make 5 cuts.
    thanks,
    Debbie
    Re: cutting 1-1/4" steel stock
    Hacksaw, jigsaw, recip saw, angle grinder . Abrasive blade will work, very messy. Metal must be clamped very well on your saw. Will probably take 5 more blades. Damage possible due to duration of cuts.
    Assuming this is a on time deal and not desiring to invest much money into a new tools?
    Jul 2016
    Thanks for the quick reply. I have a band saw and recip. saw. Which would you recommend and what blade?
    Debbie
    Before you do any cutting check the RPM of your saw AND the blade you bought. If you have the saw I'm thinking of , the RPM will not match.
    Is this 1 1/4 " Solid ? Angle ? Tube .
    Post your location, there maybe a member that could cut for you. I'll cut it if you are near Northern Illinois
    Nov 2010
    SE Nebraska
    I'm in SE Nebraska, I'd also be happy to assist!
    -Doogie
    Miller 350P
    Miller Trailblazer 325 EFI w/ Excel Power
    Lincoln LN25 suitcase welder
    XMT 304/22a feeder
    Miller Syncrowave 350LX
    Miller Econotig
    Hobart Handler 140
    (2) Uni-Hydro 42-14
    Hypertherm 65 plasma
    WEBB Gap bed lathe
    Jul 2016
    Hi,
    Thanks for the offer. It is solid. I am located in Dearborn (metro Detroit).
    If you've got a bandsaw that is the direction I would go. Blade? Buy a new one and a good one. We are talking about a bandsaw for metal, and not wood, right?
    Cut 50 Plasma
    band saw, with proper blade, first choice. Recip saw, blades readily available at hardware store.
    Apr 2012
    Flat lands of Colorado, where the wind blows
    how clean of a cut do you need? and do you have a good arc or stick welder? one can burn through it with the right rod and high setting,
    you get heavy thick solid items like that and an abrasive blade the thicker the steel the harder it is to cut it, (they may make special blades that could cut it easier, I do not know) really any thing much over 1/2 thick is slow and it get hot, hot, as it cuts, and slows down in the cutting, (if one keeps turning it so the surface it is cutting is thinner it helps, cut, rotate, cut rotate, and so on),
    may be take to a shop and pay to have it cut if you do not have any other way to cut or it needs to be a good precision cut,
    a band saw or hack saw,
    I would not suggest your Ridgid miter saw for steel, most likely the saw will be damaged in some way,
    Feb 2008
    North of Philly
    Trick I learned from one of the guys on the blacksmithing site. He has an old bow saw that he has fitted with a broken steel cutting bandsaw blade that he uses to rough cut scrap in the field. The longer "throw" to the saw lets you cut a lot more efficiently than you would with just a small hacksaw. Lowes or Depot used to sell a small bow saw frame that came with both wood and metal blades. I've been tempted to take an old 30" bow saw I have and convert it next time the blade on the horizontal bandsaw gets replaced or breaks.
    Ronald Reagan
    Hmmm.... then you could hook it up to a DC motor, battery pack and solar panel for a portable power hack saw...
    Cut 50 Plasma
    May 2011
    Andover, Ohio
    Welcome O/A will work.
    Lincoln A/C 225
    Everlast P/A 200
    Jul 2016
    Hi,
    Is there anyone in the metro Detroit area that would cut this 1-1/4" square solid steel stock for me?
    thanks,
    Debbie
    Aug 2008
    Sudbury, Ontario
    You say you have a "compound saw", this usually refers to a compound miter saw and is for woodworking only, don't use it for heavy steel, your saw is not designed for that. The metal cutting abrasive saws are built more sturdily and run at different rpm, as do the metal cutting carbide blade saws.
    Any welder or shop with oxy acetylene could do that for you. A manual hacksaw with a good blade could cut that, although slowly.
    SA 200
    Idealarc TM 300 300
    MM 200
    MM 251
    30a Spoolgun
    Precision Tig 375
    Invertec V350 Pro
    SC-32 CS 12 Wire Feeder
    Oxweld/Purox O/A
    ArcAir
    Hypertherm Powermax 85
    LN25
    Apr 2011
    minnesota
    For 5 cuts I would buy some good 14tpi sawzall blades and cut it. You can have some one spray wd40 or some other lubricant to cool the blade or cut it dry. Cut off wheel in a grinder is another option
    Millermatic 252
    millermatic 175
    miller 300 Thunderbolt
    lincoln ranger 250
    smith torches
    lots of bfh's
    Jun 2016
    Back to the jungle
    Aug 2012
    AR
    zendebi, if you would tell the folks here WHAT KIND of cut, rough or precise, you need it would help.
    Generally, O/A will be a rough cut whereas a metal cutting saw like an Evolution carbide saw or a band saw would be a more precise cut. A machine shop cut probably would be even more precise.
    Maybe consider buying the HF band saw and use a 20% or a 25% off coupon . http://www.harborfreight.com/10-amp-...kit-62800.html
    Ask them if you don't like if you can return it after using it. Make five cuts and return.
    Apr 2012
    a plain old hack saw will work, it will take some time, but for 5 or so cuts, it will not take that long, just put some elbow grease in to it and get on with life,
    Jan 2016
    northeast USA
    Quote Originally Posted by zendebi View Post
    Hi,
    thanks,
    Debbie
    where did you buy the steel? cant they for a fee cut the stock the way you want it?
Page generated in 1,632,586,609.17912 seconds with 11 queries
