Results 26 to 34 of 34
Thread: What do you use to shave aluminum?
    Apr 2013
    Marina del Rey
    Re: What do you use to shave aluminum?
    Quote Originally Posted by Blind mike View Post
    "Vixen File" is what I know those as.
    And they work great.
    Also rotary carbide cutters.
    This.
    Sep 2015
    SE Pa
    Norelco cordless
    Mar 2009
    Norelco cordless
    Seriously?! Cordless?
    Feb 2016
    East Texas
    Ive seen people use jig saws on aluminum, but then again I never really even look at aluminum!
    Forney C5 Arc Welder
    Lincoln Idealarc 250-250 Ac/Dc Arc Welder
    Miller Bobcat 225g Plus
    Lincoln PowerMig 200
    Forney O/A Rig
    Aug 2015
    My FEMI bandsaw if I'm working with tubes. My vertical mill if it's something more irregular.
    affordable 3D CAD designs using Solidworks
    HTP 221 TIG
    Millermatic 211
    PDX PNW
    I was just using a black carbonrundium grinding disk the otherday to grind a aluminum weld and it worked good, u can even put aluminum in the chop saw or cut it with a thin black cut off wheel but a band saw is much better
    Aug 2015
    Zirconium flap wheels or disc with candle wax for lubricant to keep the aluminum from clogging up the wheel. Try searching the dollar store for large candles at a bargain price. Flap disc are made from overlapping sandpaper designed to stay sharp as the paper is consumed. Zirconia is made from the Blue/Green colored granules. Stay away from the brown/red colored granules. That granule is made from aluminum oxide. Aluminum will have a tendency to stick to it more than Zirconia. If you need to clean the disc use a piece of scrap steel. When you're done grinding use acetone to clean the way and oily residue before grinding. NEVER use brake cleaner! It produces a poisons fumes when exposed to a welding arc.
  8. #33
    Quote Originally Posted by RoatanBill View Post
    I know that using an angle grinder fitted with a steel grinding or cutting disk really doesn't work too well on aluminum; I tried it.
    If one needs to shave a millimeter off the end of a piece of aluminum to make it fit properly, how does one go about it? I'm used to using an angle grinder on steel and just wearing away what I don't want. What tools and replacement parts does one use for aluminum? Whatever it is, I need to buy it, so please be specific.
    They make grinding wheel specifically for aluminum for your 4.5" grinder. Also parafin wax works well to keep discs from clogging.
  9. #34
    Sep 2015
    SE Pa
    Don't breath in the aluminum dust .Wear protection
Page generated in 1,634,862,114.15627 seconds with 13 queries
