Hi
Newbie here.
I am very seriously prospecting this model welder.
https://www.youtube.com/watch?v=nqVxqp9sqio
I have some welding experience, certainly not a lot, but some.
My prospect comes on the heels of a project that I just finished.
It is a NEMA 56 motor adaptor for Delta 6x48 belt sander that
was originally equipped with a 3Ø motor. The 1Ø motor mounting slots,
curiously did not quite match up, so... a couple of angle irons and a
1/8"x8"x8" drilled and slotted was my plan and I got er done.
The trouble with using a friend's Hobart Handler 135, isn't so much
the welder as it is that you have to pack up your parts and get there
to use his equipment and though he was generous with his welder and
his time, I felt a bit cramped about it. It all worked out fine, though.
However, I found that I'd really rather have my own welder so I can
operate on my own time when I am good and ready to do so, and
not take the risk of being liable of damaging his machine or have
to wait a couple of weeks for a window to open. - He actually
had a similar reason for purchasing his.
That being said, his Hobart Handler is set up with definitive
voltage presets, rather than the variable rheostat variety.
4 presets if I recall correctly. It did an ok job, for what I wanted
to do, but my application goes beyond what his welder is capable
of. Not much but some.
After scanning the "big three" I landed on lincoln and liked the 140 at first
then looked at the 210MP, but I get the jitters with the digital stuff as well
as the "three in one" package. I can be cynical. then I landed back
down on the 180 Dual as it has the 2 voltage options and the slightly higher
output range. I know it's not much, but for the pricepoint that I am looking
to spend, it feels right for my budget.
2 Questions:
anyway... all that said, I would like to hear opinions about this model, this setup
pros and cons and the gory details concerning this machine, if there are any.
I'd like to do some light fabrication and repair work. Maximum plate thickness
would be around 1/4"
Also, would anyone know what size stand alone portable generator would be more than
adequate for this welder would be? any recommendations? I am thinking in the 7000 watt (run)
range but open to suggestions. Oh.... yes... I need to consider a 5 hp/80 gal. air compressor
and whether the generator can handle that. It would only be one machine at a time, so...
Thank you for reading.
Sorry for the book.
:sleeping:
Newbie here.
2 Questions:
Sorry for the book.
:sleeping:
