Results 26 to 38 of 38
Thread: new tool for my shop
    Re: new tool for my shop
    Looking good. I bet you'll find things to roll that will make you appreciate that larger wheel.
    ---Meltedmetal
    Pensacola , Fla
    I rolled some flat stock to make wheels for a project I want to build. The large ones are 10" diameter rolled from 1/4" X 2" flat and the smaller ones are from 3/16" X 2". I roller the wheel in 2 halves then cut off the waste ends then welded them together. I want to make a rail road cart coffee table.
    Hypertherm 65
    Everlast PowerTig 255 EXT
    Miler 180 Mig
    13" metal lathe
    Mill/ Drill
    ECT, ECT,
    Apr 2012
    Montreal area Canada
    You will love the rail road cart, as a cart it turns on a dime and goes straight without pulling sideways, i made my welding cart on the same platform design. swivell wheels at the end might be a good toe catcher
    fantastic roller you made there
    Is that the cart you built or one you are modeling from?
    Pensacola , Fla
    Image was pulled from the net, I would think the name on the side is the builder, maybe they sell a kit?
    I plan to make changes like a top the has a cantilever hinge top, with an inlay in the top.
    I downloaded a copy of the file and cut this eagle (mine is not painted yet).
    Hypertherm 65
    Miler 180 Mig
    13" metal lathe
    Mill/ Drill
    ECT, ECT,
    Sounds like a fun project.
    Aug 2009
    missouri
    What diameter are your rollers?
  8. #33
    Quote Originally Posted by Casavam View Post
    Drawn Over Mandrel
    Correct. Most tubing is made by rolling a long sheet of metal into a tube but that will leave a seam lengthwise in the tube. Wire and DOM tubing is drawn or pulled from a hole in a vat of semi-liquid metal so there are no seams in it. If you put a button or mandrel in the middle of the hole and draw the metal then it will form a hollow tube, hence DOM tube. DOM tubing is stronger than ordinary tubing and the inner and outer surfaces are smooth and precise.
  9. #34
    Quote Originally Posted by FlaJoe View Post
    Your definition would be extruded or seamless tubing most likely aluminum.
    https://www.metalsupermarkets.com/di...seamless-tube/
    ---Meltedmetal
  10. #35
    Aug 2015
    DOM has a seam
  11. #36
    Tustin, CA
    That came out awesome. Nice job.
  12. #37
    Pensacola , Fla
    My roller diameter is 2.250"
    Here are the larger wheels finished (less paint/powder coat) and other parts for the cart cut with my CNC plasma.
    Hypertherm 65
    Miler 180 Mig
    13" metal lathe
    Mill/ Drill
    ECT, ECT,
  13. #38
    Nov 2010
    Texas
    Very nice ring roller you built Acourtjester.
    The railroad carts you reference were built out of our shop. Here is the build thread.http://weldingweb.com/vbb/showthread.php...ee-Table-Build
Page generated in 1,624,027,698.88932 seconds with 14 queries
