Results 1 to 8 of 8
Thread: Help - how to grind/sand aluminum?
    Sep 2008
    Dalton, GA
    I'm making a small art type project out of aluminum. I want to grind the TIG welds all around the edges flat and square. I almost have the outside edges done, just need to touch up some spots.
    My problem is how to grind/sand the inside oval part? Too small to get a flap disc inside and I have tried a file, but that is a slow go. I think I may just have to sand by hand to keep the edges square but again it is too slow. Are there files just for aluminum?
    I thought I would get your suggestions of a better way. Think of a football shape 1" across inside an object and the space is about 1 1/2" high by 5" long.
    Thanks for the help.
    Burt
    _____________________
    Miller Syncrowave 250
    Millermatic 211
    Miller 375 Plasma Cutter
    Hobart Handler 140
    www.10FtDrillBit.com
    Sep 2015
    SE Pa
    Re: Help - how to grind/sand aluminum?
    Sanding roll on a small grinder.Put bees wax on sanding roll will help keep alumanium from clogging up sandpaper
    Mar 2016
    Minneapolis MN
    post pics
    May 2016
    Spokane, WA
    I prefer the flap rolls in a die grinder. Most of the ones I use are 1" diameter.
    RGL Motorsports LLC
    May 2016
    Spokane, WA
    Irish Spring is the same effect.
    RGL Motorsports LLC
    Sep 2015
    SE Pa
    Smells better too
    Sep 2011
    Toronto, Canada
    And don't forget how it makes you so much more manly
    When a welder tells you to "stick it", what do they really mean?
    "In a time of universal deceit, telling the truth is a revolutionary act." - George Orwell
    Jan 2014
    Hallieford, VA
    Having had my manhood boosted (thanks, that is an accomplishment these days), pictures would still help.
    30+ yrs Army Infantry & Field Artillery, 25 yrs ago
    Miller 350LX Tig Runner
    TA 210, spool gun
    Lincoln 250/250 IdealArc
    ESAB PCM 500i Plasma
    Kazoo 30" vert BS
    Kazoo 9x16 horiz BS
    Clausing 12x24 lathe
    20T Air Press
Page generated in 1,713,276,476.84934 seconds with 20 queries
