Results 1 to 7 of 7
Thread: Lincoln Pro Mig 140 not feeding wire on setting D
    Sep 2016
    Hey guys, new on here maybe I could get some help. I have a Lincoln Pro mig 140 amp welder.
    It feeds wire. On all heat settings except D, the hottest setting. All I hear is a click from the relay inside but no feed. I turn the setting to C, B, or A and all is good welds normal. Any ideas? I'm in Hawaii so getting it repaired by Lincoln would be a headache I'm pretty handy with a soldering iron.
    Sep 2015
    SE Pa
    Re: Lincoln Pro Mig 140 not feeding wire on setting D
    Turn the switch back and forth 8-10 times .The D contact may be corroded .
    May 2011
    Andover, Ohio
    Mike. welcome to the forum.
    Lincoln A/C 225
    Everlast P/A 200
    Ceres, California
    must have weld voltage coming out of welder for feed motor to work.
    unfortunately the voltage switch is soldered to the control pcb and the pcb is potted in a plastic block. If you can find a replacement switch from an electronics store you will need to carve away the potting compound to be able to unsolder the switch.
    OR you have to buy a new pcb. Seen it done once, person who did it did a bad job.
    Had to replace the pcb because of other problems.
    Jun 2018
    Hey I know this is old but my Lincoln welder just started doing the exact same thing. Did the OP ever fix the problem? Give me a starting point please!
    Feb 2011
    Southeast Louisiana
    I have an older Century (made be Lincoln I understand) and mine does that occasionally. Seems like the switch does not always make contact when changed. I just switch it back and forth until it has a good contact and go on. The switch is getting harder to turn lately. Hope it is not too much of a problem if I need to replace.
    Hobart 190 mig
    Lincoln/Century 140 mig
    Lincoln buzz box
    Chicago Electric cutoff saw
    Lotos LTP5000D Plasma Cutter
    HMC Swivel head band saw
    Jan 2014
    Tiverton, Ontario, Canada
    Quote Originally Posted by cabranch47 View Post
    I'd try some electrical spray contact cleaner. The stuff is like magic.
Page generated in 1,632,825,073.95289 seconds with 11 queries
