Results 1 to 6 of 6
Thread: Can a flux welder operate on its side?
    Oct 2016
    I have a starter HF 90 Amp-AC, 120 Volt, Flux Cored Welder (Chicago Electric). I am wondering if there is any safety issue if I turn the unit on its side for operation?
    I have a table with a shelf that is about 10 inches below the work surface and it would be ideal if I can lay the unit on its side so it will fit on the shelf.
    Is there any reason why the unit needs to be upright during operation?
    Thanks!
    -Nick
    May 2008
    Orange, TX
    Re: Can a flux welder operate on its side?
    None that I can think of although your bead may droop to one side.
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Sep 2015
    SE Pa
    Weight of spool on side might put drag on wire feed motor.
    May 2008
    Orange, TX
    If that were the case he can just back off on the spool brake adjustment.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Jan 2015
    Martha Lake, WA
    This may go without saying, but make sure you have plenty of room for circulation and don't block off your air vents.
    Mar 2013
    Most machines are made to stand upright when it comes to cooling inside. Some components inside might overheat if you put it on the side.
    Edit:
    I've changed my mind.
    I had a look at the user's manual on your machine and it's a very simple machine and it has no top vents. The spool are only small 2 lbs spools and the spool is already on it's side when used normally (contrary to regular larger machines).
    As long as you can adjust the tension of the spool with it laying on its side I don't think you will ever run into any problems.
Page generated in 1,632,828,246.48717 seconds with 11 queries
