Results 1 to 17 of 17
Thread: 1995 miller 225g voltage problem
    Dec 2011
    archer fl
    Hi, this my first post hopefully in the right forum. Anyway I have 95 225g plus with 937 hrs, every thing works fine except for the constant voltage,when selected it puts out about 42 volts and will not adjust lower with the fine adjust. And when in the cc mode the current adjusts as it should. Also just incase its related the idle soleniod doesn't work unless i work the ignition switch back and forth fron run to idle. I'd appreciate any input anyone may have, THANKS,"RODBUSTER"
    Ceres, California
    Re: 1995 miller 225g voltage problem
    You in the right place, but I need the full model name and serial number,
    Trailblazer, bobcat, blue star ect. With out it I can't look up the service manual and diagrams.
    The Idle problem could be the Idle timer. Depending on age and model it can be on the main pcb or a smaller module. 42 volts sounds good for OCV. Look at the diagram on you cover and look for feed back wires that are sending weld voltage back to the control pcb.
    Make sure they are connected.
    Dec 2011
    archer fl
    Thanks for the reply, The full name is bobcat 225g plus, s/n#kf875070,
    THANKS "RODBUSTER"
    May 2008
    Orange, TX
    Your CV open circuit voltage (OCV) is definitely too high at 42 volts. Should be a maximum of 33 volts.
    Does it increase from 42 volts?
    When you say the CC settings adjust correctly, do you mean you can increase/decrease the output within each range with the Fine Current control or just with the Current Range selector?
    Has someone been working on the unit recently?
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Dec 2011
    archer fl
    Hi, duaneb55, The answer is yes, I did some welding with it today, And did some testing, At the highest it is 50-52 volts and lowest 40-42, And yes Fine control works corectly in cc, As far as being worked on I don't know I've owned this machine for about 3 months and this is the last kink to work out, I've opened it up to inspect but nothing was touched by me
    May 2008
    Orange, TX
    OK, that's about the correct voltage differential. Just too high.
    What is the OCV in CC/DC and CC/AC? Should be 72 and 80 respectively.
    It could be the tap strap position on trim resistor R2 is incorrect or one of the two circuit wires is on the wrong end terminal. If the CC OCVs are high, that will be the place to look.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Dec 2011
    archer fl
    Alright, The cc/dc is 95-108 and the cc/ac is 64-74. I will check the terminals when I get home this evening, I appreciate the help, electronics are not my strength,
    May 2008
    Orange, TX
    Interesting. AC is actually low and DC is way high same as CV mode. Should have seen AC higher than DC in CC. I'm still thinking trim resistor tap location and/or circuit wire position.
    Let us know what you find and if you need help on the wiring diagram just give a shout.
    In case you were wondering, this is what R2 looks like:
    Name:  Bobcat 225G Plus 14-pin 008.jpg
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Dec 2011
    archer fl
    Thanks for the picture,I adjusted the tap location out and it lowered the voltage very little
    cv 39-49 cc/dc 92-106, I'm not sure where I'm going from this point:
    May 2008
    Orange, TX
    Your targets are:
    CV - 33VDC
    CC/DC - 72VDC
    CC/AC - 80VAC
    Move the tap away from the end terminal that has the other wire connected to until OCV is within spec.
    Note the typical relationship between the tap and end terminal with the other wire in the previous photo. If the other wire is attached to the end terminal closer to the tap, OCV will be higher than specification.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Dec 2011
    archer fl
    I moved the tap as far away from the other terminal as possible and cv was 39-49 and cc/dc 92-106 ,I also moved it the other way just to make sure and the voltages just went higher
    May 2008
    Orange, TX
    OK. Let me think on this a bit.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    May 2008
    Orange, TX
    What is the AC voltage at the auxiliary power outlets??
    Locate SR2 and check AC input voltage at wires #22 & #29 or at 4-pin plug PLG6 pins #3 & #4. If you're not sure as to what you're looking for, let me know and I'll post a couple photos.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Dec 2011
    archer fl
    Pictures would be great, I'll do some testing tomorrow, THANKS ALOT
    May 2008
    Orange, TX
    PLG6/RC6 looks like this with pins #3 & #4 on the right side of the connectors. Pins #1 & #2 run down to the rotor brushes.
    Name:  Bobcat 225G Plus 4-pin PLG6-RC6.jpg
    Bridge rectifier SR2 is down in here behind all the wires . . .
    Name:  Bobcat 225G Plus SR2.jpg
    . . . and looks similar to this.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Dec 2011
    archer fl
    Ok, Auxilary power outlets are at 125v ac, And SR2 reads 24v, And somthing else interesting happened today when I removed the the top cover on the machine before I started it, I couldn't power anywhere, and when I replaced it I had power again could this be a ground problem? Also the auxilary power outlets adjust with the fine adjust control from 105-125 ?????
    May 2008
    Orange, TX
    I expected - rather hoped - auxiliary power would be higher to support my suspicions but that doesn't pan out with only 125V.
    Was SR2 reading at low idle or weld/power speed? Sorry I didn't specify but it's low either way.
    I'll be honest, nothing is adding up here. Are the batteries good in your VOM?
    . . . and now the top cover thing. Definitely check the #33 ground wires between the front panel and chassis frame.
    Oh, and the change in auxiliary output voltage when you adjust the Fine Current control is completely normal.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
Page generated in 1,635,233,788.00635 seconds with 12 queries
